Showing results forĀ
Search instead forĀ
Did you mean:Ā
wlc
sanjaygowda821
Community Member
hi Team,
we have configured AIR-AP2802I-D-K9 and added same access points in WLC .
configured SSID, interface and DHCP group, but ip not releasing.
Note: WLC controller available at different locations and access points available at different locations, we can view access points in WLC, but iP does not release.
what could be the issue
Mark Elsen
 - Have a checkup review of the mobility express controller configuration using these command(s) : https://community.cisco.com/t5/networking-knowledge-base/show-the-complete-configuration-without-breaks-pauses-on-cisco/ta-p/3115114#toc-hId-1039672820
          Feed the output into : https://cway.cisco.com/wireless-config-analyzer/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
- What model of WLC?
- What version of software?
- What do you mean by "iP does not release"?
DHCP leases expire automatically even if the client does not release the IP so it really shouldn't matter even if a client does not release the IP explicitly.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
please find my response inline
What model of WLC?--cisco 2500
What version of software? ---8.2.154.17
What do you mean by "iP does not release"? --
we placed the WLC controller one from Site A location and we added access points and IP also release.
but we added two other access points in a different location that is site B and added those two access points in the same WLC.
post we can see access points in WLC but ip is lease instead of site B segments rathan we get Site A segments.
I'm sorry but I still don't understand your explanation clearly.  I think you're saying site A/B clients are getting IPs from the other site?  If so then you probably have misconfiguration of your WLAN(s) or AP groups.  Check your config using:
using "show run-config" output from the WLC (remember "config paging disable" before running that command).
8.2.154.17 is very old and long out of support, full of bugs.  Depending on your AP models you should be running at least 8.3.150.0 or 8.5.182.7 as per TAC recommended link below.  If your APs are all 2802 then upgrade to 8.5.182.7 (link below).  If you have other models of AP you can check the compatibility matrix below for supported software versions.
