WLC4404 client up/down issue
shinwoo_acdc77
Community Member
install hardware
WLC
ACS
AP1131
WPA1+TKIP, H-REAP
Client high frequently reconnect(roaming in APs), i think WLC RRM Problem ..I attack WCS log please help me..
all WLC is same RF group... (no need roaming)
bwilmoth
Level 10
Level 10
You may try investigating the channel/power setting to see if there was a misconfiguration that was causing your client roaming issue.
