03-06-2025 05:33 AM - edited 03-06-2025 05:34 AM
The AP fails to join.
There is a problem with the WLC trust point.
WLC-01#show wireless stats ap history | inc Disjoined
APC4D6.6693.3350 4800.b33a.ec40 Disjoined 03/06/25 21:58:37 03/06/25 22:18:39 DTLS cert-chain not available 13
APC4D6.6693.35C0 4800.b33a.f120 Disjoined 03/06/25 21:58:25 03/06/25 22:19:31 DTLS cert-chain not available 14
APC4D6.6693.36B0 4800.b33a.f300 Disjoined 03/06/25 21:58:28 03/06/25 22:19:14 DTLS cert-chain not available 13
APC4D6.6693.3A50 4800.b33a.fa40 Disjoined 03/06/25 21:58:33 03/06/25 22:18:40 DTLS cert-chain not available 13
APC4D6.6693.3D00 4800.b33a.ffa0 Disjoined 03/06/25 21:58:28 03/06/25 22:18:35 DTLS cert-chain not available 13
WLC-01#show wireless management trustpoint
Trustpoint Name :
Certificate Info : Not Available
Private key Info : Not Available
FIPS suitability : Not Applicable
WLC-01#show crypto pki trustpoints
Trustpoint DNAC-CA:
Subject Name:
ou=Cisco DNA Center
o=Cisco Systems
cn=207efc7d-15e0-93ba-7a60-63aa8ff267a2
Serial Number (hex): XXXXX
Certificate configured.
Trustpoint sdn-network-infra-iwan:
Subject Name:
cn=sdn-network-infra-ca
SCEP URL: http://XXXXX:80/ejbca/publicweb/apply/scep/sdnscep
Trustpoint SLA-TrustPoint:
Subject Name:
cn=Cisco Licensing Root CA
o=Cisco
Serial Number (hex): 01
Trustpoint CISCO_IDEVID_SUDI:
Subject Name:
o=Cisco
cn=High Assurance SUDI CA
Trustpoint CISCO_IDEVID_SUDI0:
Subject Name:
cn=Cisco Root CA 2099
o=Cisco
WLC-01#show crypto pki certificates
Certificate
Status: Available
Certificate Serial Number (hex): XXXXX
Certificate Usage: General Purpose
Issuer:
o=Cisco
Subject:
Serial Number: PID:C9800-L-F-K9 SN:XXXXX
cn=C9800-L-F-K9
ou=ACT-2 Lite SUDI
o=Cisco
serialNumber=PID:C9800-L-F-K9 SN:XXXXX
Validity Date:
start date: 15:26:27 JST Dec 14 2024
end date: 05:58:26 JST Aug 10 2099
Associated Trustpoints: CISCO_IDEVID_SUDI
CA Certificate
Status: Available
Certificate Usage: Signature
Issuer:
o=Cisco
Subject:
o=Cisco
CRL Distribution Points:
http://www.cisco.com/security/pki/crl/crca2099.crl
Validity Date:
start date: 05:28:08 JST Aug 12 2016
end date: 05:58:27 JST Aug 10 2099
Associated Trustpoints: CISCO_IDEVID_SUDI Trustpool
CA Certificate
Status: Available
Issuer:
o=Cisco
Subject:
o=Cisco
Validity Date:
start date: 05:58:28 JST Aug 10 2016
end date: 05:58:28 JST Aug 10 2099
Associated Trustpoints: CISCO_IDEVID_SUDI0 Trustpool
CA Certificate
Status: Available
Certificate Serial Number (hex): 01
Issuer:
o=Cisco
Subject:
o=Cisco
Validity Date:
start date: 04:48:47 JST May 31 2013
end date: 04:48:47 JST May 31 2038
Associated Trustpoints: Trustpool SLA-TrustPoint
Storage: nvram:CiscoLicensi#1CA.cer
Certificate
Status: Available
Issuer:
Subject:
cn=C9800-L-F-K9_FCL284700CC_sdn-network-infra-iwan
hostname=WLC-01
Validity Date:
start date: 19:57:15 JST Mar 5 2025
end date: 19:57:15 JST Mar 5 2026
renew date: 19:57:15 JST Dec 22 2025
Associated Trustpoints: sdn-network-infra-iwan
Storage: nvram:sdn-network-#76D3.cer
CA Certificate
Status: Available
Issuer:
Subject:
Validity Date:
start date: 13:00:54 JST Feb 13 2025
end date: 13:00:53 JST Feb 13 2045
Storage: nvram:sdn-network-#94A5CA.cer
CA Certificate
Status: Available
Issuer:
ou=Cisco DNA Center
o=Cisco Systems
cn=XXXXX
Subject:
ou=Cisco DNA Center
o=Cisco Systems
cn=XXXXX
Validity Date:
start date: 11:05:44 JST Feb 13 2025
end date: 11:05:44 JST Nov 10 2027
Associated Trustpoints: DNAC-CA
Storage: nvram:CiscoDNACent#6723CA.cer
WLC-01# wireless config vwlc-ssc
% Invalid input detected at '^' marker.
I tried to create a trustpoint manually, but the command is not supported.
Solved! Go to Solution.
03-06-2025 09:28 PM - edited 03-06-2025 09:30 PM
WLC-01-stby#show crypto pki certificates
Certificate
Status: Available
Certificate Serial Number (hex): xxxxx
Issuer:
cn=Cisco Manufacturing CA III
o=Cisco
Subject:
Serial Number: PID:C9800-L-F-K9 SN:xxxxx
serialNumber=PID:C9800-L-F-K9 SN:xxxxx
cn=SWSUDI
http://www.cisco.com/security/pki/crl/cmca3.crl
Validity Date:
start date: 15:30:53 JST Dec 14 2024
end date: 04:19:27 JST May 27 2099
Associated Trustpoints: CISCO_IDEVID_CMCA3_SUDI
WLC-01#reload slot 1
WLC-01#show chassis
Chassis/Stack Mac Address : f8c6.5022.4300 - Local Mac Address
Mac persistency wait time: Indefinite
Local Redundancy Port Type: Twisted Pair
H/W Current
Chassis# Role Mac Address Priority Version State IP
1 Standby f8c6.5022.4300 2 V02 Ready 169.254.1.250
*2 Active f8c6.5022.4380 1 V02 Ready 169.254.1.253
WLC-01(config)#wireless management trustpoint CISCO_IDEVID_CMCA3_SUDI
Trustpoint Name : CISCO_IDEVID_CMCA3_SUDI
Certificate Info : Available
Certificate Type : MIC
Certificate Hash : cad50797657de9ed82bb495f8fe713aa5b952106
Private key Info : Available
WLC1 does not have a Cisco Manufacturing CA certificate.
However, we found a Cisco Manufacturing CA III certificate for WLC2.
We will contact the TAC for the WLC1 controller.
03-06-2025 06:30 AM
- If this is a virtual 9800-CL controller then you need to generate the WMI's trustpoint manually using the command :
wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 0
Referenced in : https://www.ciscolive.com/c/dam/r/ciscolive/global-event/docs/2024/pdf/BRKEWN-2094.pdf
Start reading from : Uplink IP and Wireless Management Interface (WMI)
(don't forget to configure the WMI neither)
If you get this on another controller (a physical box) ; then checkout it's configuration first
using the CLI command show tech wireless and feed the output from that into Wireless Config Analyzer
Look for related advisories ; (use the full command denoted in green do not use show tech-support
for this procedure)
M.
03-06-2025 06:37 AM
It's not 9800CL, it's 9800-L-F
17.12.4 ver
03-06-2025 06:44 AM - edited 03-06-2025 06:46 AM
Take a look at this guide. You can always use an existing trustpoint or just create a new one. Under Configuration > Interface > Wireless, you can choose a different one that is existing.
03-06-2025 05:47 PM - edited 03-06-2025 05:48 PM
03-06-2025 06:38 PM
Do you not have another SUDI trustpoint you can use?
03-06-2025 10:16 PM
HYS-MPO-ITR-SDA-WLC-(config)#wireless management trustpoint CISCO_IDEVID_SUDI
% node-2:dbm:wireless:Default Cisco SUDI trustpoint name is not allowed
SUDI is not allowed for trust pont and SUDI0 has no effect.
03-06-2025 06:49 AM
- @JustTakeTheFirstStep >...It's not 9800CL, it's 9800-L-F
Normally not needed on these boxes ; use the WirelessAnalyzer procedure too as I explained in my first reply and look at the info's from @Scott Fella too.
M.
Certificate
Status: Available
Issuer:
o=Cisco
Subject:
cn=SWSUDI
Validity Date:
WLC-01#show chassis
H/W Current
03-09-2025 06:38 PM
1. Always mention the specific model of WLC and version of software which it is running!
2. The correct trustpoint for latest versions of software on hardware appliance WLCs (not 9800-CL) is CISCO_IDEVID_CMCA3_SUDI:
9800#sh wireless management trustpoint
9800#sh crypto pki trustpoints | beg CISCO_IDEVID_CMCA3_SUDI
Trustpoint CISCO_IDEVID_CMCA3_SUDI:
Subject Name:
o=Cisco
03-09-2025 07:01 PM
WLC-01#sh ver
Cisco IOS XE Software, Version 17.12.04
WLC-01#sh inven
NAME: "Chassis 1", DESCR: "Cisco C9800-L-F-K9 Chassis"
PID: C9800-L-F-K9 , VID: 03 , SN:
Check out “sh crypto pki certificates” in the main body
The CISCO_IDEVID_CMCA3_SUDI certificate for WLC1 is not provided.
03-10-2025 12:22 AM
Modified Trustpoints for Secure Unique Device Identity (SUDI) Certificates
From Cisco IOS XE Dublin 17.12.1 onwards, the following changes have been introduced for trustpoints:
Trustpoint names for existing SUDI certificates
If your device supports Cisco Manufacturing CA III certificate and is not disabled, the trustpoint names are as follows:
For Cisco Manufacturing CA III certificate, the trustpoint name has changed from CISCO_IDEVID_SUDI to CISCO_IDEVID_CMCA3_SUDI
For Cisco Manufacturing CA SHA2 certificate, the trustpoint name has changed from CISCO_IDEVID_SUDI_LEGACY to CISCO_IDEVID_CMCA2_SUDI
If your device does not support Cisco Manufacturing CA III certificate or if the certificate is disabled using no platform sudi cmca3 command, the trustpoint names are as follows:
For Cisco Manufacturing CA SHA2 certificate, the trustpoint name has changed from CISCO_IDEVID_SUDI to CISCO_IDEVID_CMCA2_SUDI
For Cisco Manufacturing CA certificate, the trustpoint name has changed from CISCO_IDEVID_SUDI_LEGACY to CISCO_IDEVID_CMCA_SUDI
Hardware SUDI certificates
If your device supports High Assurance SUDI CA certificate, this certificate is loaded under CISCO_IDEVID_SUDI trustpoint.
If your device does not support High Assurance SUDI CA certificate, ACT2 SUDI CA certificate is loaded under CISCO_IDEVID_SUDI trustpoint.
show wireless management trustpoint command output
If Cisco Catalyst 9300 Series Switch is used with a Cisco Catalyst 9800 Series Wireless Controller for wireless deployments, the trustpoint name in the output of show wireless management trustpoint command is updated to the modified trustpoint name as mentioned previously.
The following example shows a sample output of show wireless management trustpoint command. Note that if your device does not support Cisco Manufacturing CA III certificate or if the certificate is disabled, the Trustpoint Name in the following output displays CISCO_IDEVID_CMCA2_SUDI.
Device# show wireless management trustpoint
Certificate Hash : <SHA1 - hash>
show ip http server status command output
If you configure the trustpoint for the HTTP server as CISCO_IDEVID_SUDI, the output of show ip http server status command displays the operating trustpoint along with the configured trustpoint.
The following example shows a sample output of show ip http server status command with both the configured and the operating trustpoint names. Note that if your device does not support Cisco Manufacturing CA III certificate or if the certificate is disabled, the operating trustpoint in the following output displays CISCO_IDEVID_CMCA2_SUDI.
Device# show ip http server status
HTTP secure server trustpoint: CISCO_IDEVID_SUDI
HTTP secure server operating trustpoint: CISCO_IDEVID_CMCA3_SUDI
So check that you don't have "no platform sudi cmca3" configured? The certificate comes from the software so it doesn't make sense that it should be missing from hardware.
