WLSE and SNMP trap generation
richard-hughes
I've recently installed WLSE 1.3 and upgraded to 2.0. On both versions I'm not receiving snmp traps from the WLSE on my network management system.
Syslog is working a treat.
When viewing the ADMINISTRATION->Appliance->snmpd.log I get the following output:
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (UCD-DLMOD-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 0 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TM): At line 0 in (none)
UCD-SNMP version 4.2.3
This occurred on version 1.3 before I upgraded.
The WLSE is however interrogating AP's via SNMP with no problems.
Can somebody help?
rmushtaq
Level 8
Level 8
WLSE supports only SNMP v2c traps. For example, Solaris 2.8-based NetView 7.1 receives and displays the SNMP v2c fault notification traps from WLSE. Windows-based NetView 7.1 supports only v1 traps and cannot receive and display any v2c traps from the WLSE. The following MIB defines the trap and the varbinds: CISCO-DEVICE-EXCEPTION-REPORTING-MIB.my. It can be downloaded from CCO and loaded into the trap receiver. Make sure that you have setup the trap receiver's credentials correctly in WLSE under Faults->Notification Settings
