WLSE Device Specific Configurations
robertaungst
Frequent Visitor
Frequent Visitor
I get an error when trying to use the device specific configuration:
15:34:43 02/09/2006 Device: usedevicespecific(AP1210, 12.3(2)JA2, 00137f39c4c3)
---Error applying configuration.
Does anyone have this working?
rmushtaq
Level 11
Level 11
What do the Job Run Detail->Job Run Log show for this?
Here is the complete job run log:
08:26:47 02/10/2006 Device: usedevicespecific.mathsciencec(AP1210, 12.3(2)JA2, 00137f39c4c3)
---Applying template( SSH-Setup-Version5 ) configuration to the device.
---Device Specific Parameters for this device are : hostName = APD-D020, sysLocation = null, sysContact = null, radioa_channel = 0, radioa_power = 0.0, radiobg_channel = 0, radiob_power = 0.0, radiobg_power_cckm = 0.0, radiobg_power_ofdm = 0.0, customCommand = null.
08:38:18 02/10/2006 Device: usedevicespecific.mathsciencec(AP1210, 12.3(2)JA2, 00137f39c4c3)
It looks like it runs the first part ok. This actually changes the hostname. Then it tries to send the device specific config, but can't find it because the host name has changed.
I can see the device under group management with the new host name.
I know I can run custom commands that don't include the host name since it's already set. However, I would like to get this working for future jobs to run.
Could it be that you did not enter the dB or mW identifiers to the CSV file?
I found out that not only the levels must be specified but also these parameters.
Bas Kokken
