WLSE: problems displaying correct bands
ruben.montes
Level 4
Level 4
I have a network composed of AP1200 working in the 802.11g band. When I try to see the theorical coverage of each of them with the Coverage Display option, with the 802.11g filter I can't see anything, but with the 802.11a I see the coverage.
Has anyone else faced this problem? Maybe a bug?
Thanks and best regards,
Ruben
lanceneher
Community Member
I have had the same problem the fix was to upgrade to newer IOS code
rmushtaq
Level 11
Level 11
This is an IOS bug. Upgrade to the latest 12.3(2)JA for the fix.
