WLSE reports problem
N3t W0rK3r
Level 6
Level 6
I am prevented from running a report on my WLSE (Wireless Clients, for example) because the year drop-down box contains only "dddd" instead of a list of years to choose from.
How can I fix this?
Thanks.
John
This problem is a bug that version 2.13 has. The bug ID is the following:
CSCsd66542.
This happens only for WLSE 2.13 release when user other than
'admin' login to WLSE and access the reports.
Please do the following steps to correct this error:
1) Login WLSE with the 'admin' user.
2) Go to http://:1741/debug/dbupdate.jsp
3) Copy & Paste the following query: insert into hsa_rolecodes ( select roleid ,
'/wlse/selection.js' from hsa_roles)
fmeetz
Level 8
Level 8
The year issue is a known problem. The workaround for this is to upgrade the WLSE firmware to the latest version. This will resolve this issue.
CSCsd66542.
sancy
Community Member
Thanks a lot for this information. I also had this bug, and now it's solved !!
It really helps, thanks one more time
Thanks very much. That fixed it!
John
