wlsm with fwsm question
justin.donoghue
Question I have is related to the following setup. WLSM and access points (L3 roaming)incorporated into 6500 with FWSM. The FWSM is firewalling 2 wireless networks. Access points have BVI on seperate subnet with subinterfaces on fastethernet defining vlans for 2 ssid's. BVI subnet has HSRP address for default gateway on the access points. The issue is as part of a security audit it was discovered that wireless clients were recieving HSRP traffic even though they should be completely seperate from the rest of the network via the FWSM. IS this normal or am I missing something?
mchin345
Level 6
Level 6
In relevance to this issue, you have mentioned that " The FWSM is firewalling 2 wireless networks". So, can you send me the firewall configuration?. Also, send me the network topology. These two information will be really helpful for furher analysis.
