04-26-2006 01:10 PM - edited 07-04-2021 11:59 AM
Is it possible to enable dot1x and voice on the same interface? If so which switches and IOS support this feature ?
Any references to documents ?
Commands that cannot be configured together :-
switch voice vlan xxx
dot1x port-control auto
Solved! Go to Solution.
04-27-2006 04:46 AM
It is possible to enable 802.1X and voice on the same port. If the phone does CDP, it is allowed through, regardless of the 802.1X state of the port with this config. Here's the following switches that support this, with the minimum required releases:
CatOS (6500) - 7.6(1)
IOS (4500) - 12.1(20)EWA
IOS (3750) - 12.2(25)SEA
IOS (3560) - 12.2(25)SEA
IOS (3550) - 12.1(12c)EA1
IOS (2960) - 12.2(25)FX
IOS (2950) - 12.1(12c)EA1
IOS (2940) - 12.1(13)AY
Hope this helps,
04-27-2006 04:46 AM
Hope this helps,
