WPA3-Enterprise 6 GHz SuiteB only SSID and roaming
patoberli
Hi All
I'm currently troubleshooting a 6 GHz only SSID on a 9800 WLC with 17.9.5 and 9166 APs. The SSID is setup with WPA3-Enterprise and SuiteB, as per the guide here:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/220712-configure-and-verify-wi-fi-6e-wlan-layer.html#toc-hId--2092915632
I discovered now that this variant doesn't support Fast Transition (802.11r). The radius server is an ISE cluster with EAP-TLS as computer authentication.
I have now issues with roaming, that it will take > 3 seconds for the roam. Is this normal and to be expected when using WPA3-Enterprise + GCMP256 cipher + SUITEB192-1X?
The SSID is solely on 6 GHz, but there are other SSIDs distributed on the same AP. A PCAP of the client shows that it's doing full authentications.
When checking the radioactive trace, I can see exact 3,00x seconds between the following two states:
Mobility Announce
Mobility HandOff
Also the following errors are shown when the client tries to roam, after which it will start a fresh and successful authentication:
2024/06/05 11:13:46.024client-orch-smClient started layer 2 authentication (either dot1X or PSK)
2024/06/05 11:13:46.029client-keymgmtSent M1 for EAPOL 4-Way Handshake
2024/06/05 11:13:47.029client-keymgmtController did not receive response for M1, sending retransmission
2024/06/05 11:13:48.029client-keymgmtController did not receive response for M1, sending retransmission
2024/06/05 11:13:49.030client-keymgmtReached maximum retries for M1
2024/06/05 11:14:37.151client-orch-smController initiated client deletion with code: CO_CLIENT_DELETE_REASON_KEY_MGMT_MIC_VALIDATION. Explanation: if WLAN is PSK, possible invalid password. For 802.1x, this is client side supplicant issue. Actions: For PSK, check password on WLAN and client side. For 802.1x, contact client manufacturer
2024/06/05 11:14:37.153dot11Disassociation packet sent with code status: 15
Those heavily point to a driver issue, but we tried Intel drivers 23.40 and also the newest 23.50 with the same result.
Do you think it's indeed the client?
Patrick
patoberli
Hi all
The final solution was more simple than though, WLC upgraded to 17.12.3 and now it works as it should. Not sure if the customer switched back to normal WPA3-Enterprise without NSA ciphers or not.
5 Replies 5
marce1000
  - We see a similar error (CO_CLIENT_DELETE_REASON_KEY_MGMT_MIC_VALIDATION) being reported in : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy55746
                               Known Fixed Releases (0)....
 M.
JPavonM
FT over SuiteB is a known missing feature that would be added on a next code iteration but, why are you testing SuiteB and not standard WPA3-128bit? Unless your clients would be Win11 (no Win10 support for SuiteB, and 6Ghz of course), and your environment requires the use of such NSA-grade security, it has little sense.
Actually, I'm fairly sure that two days ago, my Windows 11 didn't offer WPA3-Enterprise with AES as an option, or I was blind. In any case, today it's available and am currently doing tests.
JPavonM
That's the same for me too, maybe Microsoft have received a care reminder to provide both WPA3 flavours and not just the NS grade one.
patoberli
Hi all
