Yoto wireless device will only connect to one of many SSIDs on WLC
We have 10 Yoto Players and about half of them will not connect to the preferred SSID.  Through testing I found that it would connect to one specific SSID.  I created a test SSID and applied it to the same WLC interface that mysteriously worked and I was able to connect the device.  If I then move the SSID to any other interface it fails to connect.  I have compared the two interfaces and their is no differences aside from vlan #, subnet and gateway.  I also compared the vlan interfaces on the core switch and their is again on IP differences no other differences that I can see.  I setup a monitoring session and used wireshark to compare the packet captures.  I applied a filter to the output to view only activity with the MAC address of the yoto player.  On the working SSID, the first thing I see is a broadcast message then the device syncs up and communicates.  On any non-working SSID there is simply no traffic showing from that filtered MAC.
Anyone run into anything like this before?
ammahend
whats the policy manager state when it does not connect ?
also share the wireshark capture that you did.
share controller model and version, can suggest few debugs to do additional checks.
-hope this helps-
Controller = 2504
Version = 8.5.182.0
from clients view, Status = Associated and Auth = Yes
Prince.O
It seems the issue may be related to the interface/vlan configuration on the controller or possible communication issue on the switching side for that subnet
What controller model and code are you running ?
On the controller, what state do we see the client in when they encounter the problem ?
I would validate the following :
- The dynamic interface configuration is correct on the controller configuration ( ip address, subnet, gateway, DHCP server , etc)
- In the packet capture, I would filter on "dhcp" to validate the client is able to get an ip address or see where the communication fails.. if you see a DHCP broadcast being sent out and no respond back then may be a DHCP issue
Leo Laohoo
Update the firmware of these machines because this has all the hallmark of a poorly-written wireless NIC code.
