/32 static route problem in a vrf
Deniz AYDIN
  I have configured /32 route for a vrf which has /24 route for that prefix from another vrf. I am able to see /32 prefix in mpls forwarding table but AIB seems to be empty. When I have changed from /32 to /30, the problem is solved.
show route vrf test
Mon Jun  1 11:02:36.824 EEST
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR
       A - access/subscriber, a - Application route, (!) - FRR Backup path
Gateway of last resort is 10.0.0.2 to network 0.0.0.0
S*   0.0.0.0/0 [1/0] via 10.0.0.2, 2d19h
C    10.0.0.0/30 is directly connected, 2d20h, GigabitEthernet0/0/0/10.4045
L    10.0.0.1/32 is directly connected, 2d20h, GigabitEthernet0/0/0/10.4045
B    192.168.97.0/24 is directly connected, 2d17h, BVI97 (nexthop in vrf TN_NMC)
S    192.168.97.179/32 [1/0] via 10.0.0.2, 2d17h, GigabitEthernet0/0/0/10.4045
show mpls forwarding vrf test detail
Mon Jun  1 11:03:53.240 EEST
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
16470  Unlabelled  0.0.0.0/0[V]       Gi0/0/0/10.4045 10.0.0.2        828
     Updated May 29 17:48:01.935
     Version: 113, Priority: 3
     MAC/Encaps: 18/18, MTU: 9000
     Label Stack (Top -> Bottom): { Unlabelled }
     NHID: 0
     Packets Switched: 9
289891 Unlabelled  192.168.97.179/32[V]   \
                                      Gi0/0/0/10.4045 10.0.0.2        0
     Updated May 29 17:56:09.341
     Version: ?, Priority: ?
     MAC/Encaps: ?/?, MTU: ?
     Label Stack: { ? }
     Packets Switched: ?
    show mpls forwarding vrf deltapetrol detail
    Mon Jun  1 11:05:17.918 EEST
    16023  Unlabelled  192.168.97.176/30[V]   \
         Updated Jun  1 11:05:12.288
         Version: 690, Priority: 3
         NHID: 0x7a
         Packets Switched: 0
         Updated May 29 17:48:01.936
         NHID: 0
         Packets Switched: 9
is a possibility indeed. jsut as additional FYI, the cisco live preso 2904 from sanfran 2014 has some detail about that rib behavior if you like more info and some show commands on how to track that down/verify.
xander
8 Replies 8
DIEGO ZORRILLA
Can you provide additional info? configuration? the outputs when the /30 is configure insted of /32?
yeah a config would also help here I think. I'd like to see what vrf and config for Gi0/0/0/10.4045 was done. it seems a bit off that is unlabeled and then this interface is referenced in 2 vrf's, which can be done, if it was mpls enabled, but then it seems to target unlabeled.
show mpls ldp ne would also be helpful here.
xander
Hi all,
Sorry for delay. Its related with cef. I found a simalar case ;
CSCse46790 CEF prefers ARP adjacency over RIB next hop - See more at: https://supportforums.cisco.com/document/12098096/cscse46790-cef-prefers-arp-adjacency-over-rib-next-hop#sthash.7w4Dy3rb.dpuf
cef adjacency route override rib disable command solved my problem and we are planning it to apply on live env. But I am sure its gonna solve the problem.
xander
definitely the same scenario (I remember that I saw this in the cisco live docs, but unable to find it than I posted:)
More detail about the configuration.
Two VRF'es, TEST and CE_TEST are configured. One VRF, TEST, has 10.20.97.0/24 prefix connected and the customer vrf, CE_TEST, is importing that but also has more specific route inside that prefix, 10.20.97.2/32, configured statically. Without that command you see the host route in the CE_TEST rib but fib shows the remote adjency in the TEST vrf for the 10.20.97.2/32.
after the command applied rib install in fib of the vrf.
vrf TEST
 address-family ipv4 unicast
  import route-target
   12735:910
  export route-target
   12735:900
vrf CE_TEST
  import route-target
   12735:900
  export route-target
   12735:910
interface BVI97
 description ### TEST ###
 mtu 9014
 vrf TEST
 ipv4 address 10.20.97.3 255.255.255.0
interface GigabitEthernet0/0/0/0.17
 vrf CE_TEST
 ipv4 address 10.0.0.1 255.255.255.252
 encapsulation dot1q 4045
router static
 vrf CE_TEST
   0.0.0.0/0 10.0.0.2
   10.20.97.2/32 10.0.0.2
show route vrf CE_TEST
Mon Jun 29 06:59:15.194 UTC
C    10.0.0.0/30 is directly connected, 2d19h, GigabitEthernet0/0/0/0.17
L    10.0.0.1/32 is directly connected, 2d19h, GigabitEthernet0/0/0/0.17
B    172.16.1.0/29 is directly connected, 2d17h, BVI16 (nexthop in vrf TEST)
B    10.20.97.0/24 is directly connected, 2d17h, BVI97 (nexthop in vrf TEST)
S    10.20.97.2/32 [1/0] via 10.0.0.2, 2d17h
sh cef vrf CE_TEST 10.20.97.2/32 hardware  egress location 0/0/CPU0
10.20.97.2/32, version 0, internal 0x4480001 0x0 (ptr 0x88448264) [1], 0x0 (0x8838cf70), 0x0 (0x0)
 Updated Jun 29 06:54:41.910
 local adjacency 10.20.97.2
 Prefix Len 32, traffic index 0, Adjacency-prefix, precedence n/a, priority 0
   via 10.20.97.2, BVI97, 6 dependencies, weight 0, class 0 [flags 0x0]
    path-idx 0 NHID 0x0 [0x8a491aa8 0x0]
    next hop VRF - 'TEST', table - 0xe0000014
    next hop 10.20.97.2
    local adjacency
    Mon Jun 29 07:00:18.249 UTC
    10.20.97.2/32, version 26, internal 0x4000001 0x0 (ptr 0x88448264) [1], 0x0 (0x0), 0x0 (0x0)
     Updated Jun 29 06:59:52.650
     Prefix Len 32, traffic index 0, precedence n/a, priority 3
       via 10.0.0.2, 5 dependencies, recursive [flags 0x0]
        path-idx 0 NHID 0x0 [0x88447c64 0x0]
        next hop 10.0.0.2 via 10.0.0.2/32
Sumanta Ghosh
Hi Experts
I am facing similar issue in IOS-XR. We have two different VRFs (A and B) and we are trying to leak routes selectively via inter-VRF static. It is not working everytime as expected. Appears to be intermittent issue. Does the below look ok in IOS-XR? It broke down 3 days back. Although it is working fine for few other /32 routes.
router static
 vrf A
   10.0.91.5/32 vrf B description ***Route-1***
   10.20.3.6/32 vrf B 10.20.3.18 description ***Route-2***
   10.33.211.152/29 vrf B description ***Route-3***
router static
 vrf B
   10.20.3.6/32 10.20.3.18 description ***Route-4***
   10.32.0.0/22 vrf A description ***Route-5***
sh cef vrf A 10.33.211.156 detail
Fri Sep 15 18:19:50.238 BST
10.33.211.152/29, version 6, internal 0x1000401 0x0 (ptr 0x72164914) [1], 0x0 (0x71fc0090), 0xa20 (0x723fa230)
 Updated Sep 15 10:38:17.013
 Prefix Len 29, traffic index 0, precedence n/a, priority 3
  gateway array (0x71dcedd4) reference count 4, flags 0x20068, source rib (7), 0 backups
                [5 type 4 flags 0x208401 (0x7242c5d0) ext 0x0 (0x0)]
  LW-LDI[type=1, refc=1, ptr=0x71fc0090, sh-ldi=0x7242c5d0]
  gateway array update type-time 1 Sep 15 10:38:17.012
 LDI Update time Sep 15 10:38:17.013
 LW-LDI-TS Sep 15 10:38:17.013
   via 0.0.0.0/32, 0 dependencies, weight 0, class 0 [flags 0x0]
    path-idx 0 NHID 0x0 [0x7156b110 0x0]
    next hop VRF - 'B', table - 0xe0000011
    next hop 0.0.0.0/32
     local label 24007      labels imposed {None}
    Load distribution: 0 (refcount 5)
    Hash  OK  Interface                 Address
    0     Y   Unknown                   Lookup in table
RP/0/RSP0/CPU0:LD6-DCGW-SR01#
sh cef vrf B 10.32.0.132 detail
Fri Sep 15 18:20:43.630 BST
10.32.0.128/25, version 72, internal 0x1000001 0x0 (ptr 0x72170fb4) [1], 0x0 (0x71fc11e8), 0x0 (0x0)
 Updated Sep 15 17:56:05.472
 Prefix Len 25, traffic index 0, precedence n/a, priority 3
  gateway array (0x71dcddd8) reference count 2, flags 0x0, source rib (7), 0 backups
                [3 type 3 flags 0x8401 (0x71e94710) ext 0x0 (0x0)]
  LW-LDI[type=3, refc=1, ptr=0x71fc11e8, sh-ldi=0x71e94710]
  gateway array update type-time 1 Sep 15 10:35:56.509
 LDI Update time Sep 15 10:35:56.509
 LW-LDI-TS Sep 15 17:56:05.472
    path-idx 0 NHID 0x0 [0x7156b090 0x0]
    next hop VRF - 'A', table - 0xe0000014
    next hop 0.0.0.0/32
    Load distribution: 0 (refcount 3)
Please provide the configuration for route leaking.
Initially I had only given inter-VRF routes, for summary subnets between two VRFs. However TAC suggested me to use next hop or directly attached interface in the static route syntax. The IOS-XR was allowing the statement without any next hops and it was working well, when suddenly it broke down.
