A fatal error was reported by SAR firmware during initialization
Dears,
After upgrading the SMU to one of our IOS XR GSR, we got the following error:
g_spa_2[173]: SPA ATM1/2 SAR: A fatal error was reported by SAR firmware during initialization: Firmware version mismatch [Error code 2002]. SPA will reset
The line card went into constant reload.
I could not locate any bug related.
Could it be hardware issue ?
Michel.
xthuijs
it could be the wrong hw rev for the atm spa is used (I thought you needed a V2).
that could be part of the problem.
alternatively, I would let the SIP boot without the SPA, invoke a fpd update, insert the SPA, try to update the fpd of the SPA, if that still fails, I think you need to open a tac case.
doesnt look like a hw failure to me, but this is a hw issue (fw revision situation)
regards
xander
Xander Thuijs CCIE #6775
Principal Engineer
ASR9000, CRS, NCS6000 & IOS-XR
zhangyaotian
Hi mbousleiman,
Sorry to reply here, I want to know the solution for another problem you faced before regarding ASR1K PAT 1:1 translation,as that post already closed.
Please share.indecision
Yaotian
