A99-RSP-SE Per Linecard Fabric Bandwidth
NullRoute
If I have an ASR 9910 with no FCs only two RSPs (A99-RSP-SE), what is the maximum Per Slot Fabric I can get?
Smilstea,
 Thanks for the reply, I really appreciate it. I saw that previously, I was just confused. IT says 230 Gbps bidirectional switching capacity per RSP. So if I have two RSPs is that 460Gbps per Line Card? I know the SerDes links are active/active to each RSP.
