A9K-MOD80-SE A9K-MOD80-TR difference
Yuyang Jin
Hi there,
Can anyone tell me the difference between A9K-MOD80-SE and A9K-MOD80-TR in details. I understand that the scale of QoS and EFPs are different, but what are the details?
17 Replies 17
you'll have 8k policers on teh TR card, so that scales to some extent.
shapers you only have 8 per port so that is very limited for the TR card.
so while you can do pwhe on tr and use policers, just be mindful on the support situation.
in case you do see something I would recommend removing the qos, to see if that affects the issue seen. if not, then there is something generically wrong with pwhe, if that solves the issue it pertains to qos and then you know what the answer will be :)
xander
How I get this  Cisco live ID ???
Hi Rick,
Is there a limitation throughput with these 2 difference module? or how many maximum throughput for A9K-MOD80-SE and A9K-MOD80-TR?
