A9K-MPA-4X10GE is not allowed
isbou1986
I'm new in this forum, and I've been searching a solution for my issue I did not find any, so I decided to post my own and hope that someone can help me to solve the issue.
As per the subject, I have inserted one A9K-MPA-4X10GE in my router which is running on IOS 5.3.1[Default], the issue is that the card is not coming up. When I type show platform I have below output
Node      Type                     State                        Config State
0/0/1 A9K-MPA-4X10GE NOT ALLOW ONLIN NPWR,NSHUT,MON
Any one can help me to find why I have this situation and how to bring up the card so that I can use interfaces.
Thanks in advance.
nkarpysh
One possibility is that you may need to have a license in order to activate the slot. see below link:
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/data_sheet_c78-728237.html
Two integrated 10 Gigabit Ethernet SFP+ ports and the Bay 0 slot is enabled by default in the Cisco ASR 9001-S. Another two integrated 10 Gigabit Ethernet SFP+ ports and the Bay 1 slot can be enabled by applying an upgrade license.
Hope this helps,
Niko
HTH,
Niko
