Activate license for CGN NAT
Hi all.
I have one question, how can activate license for CGN in CRS-3.
I testing whit this command.
RP/0/RP0/CPU0:(admin-config)#license XC-XLAT44-5M location 0/3/CPU0
In linecard 0/3/CPU0 is my CGN NAT, after of config  RP/0/RP0/CPU0:(admin-config)#license XC-XLAT44-5M location 0/3/CPU0
I no see change.
RP/0/RP0/CPU0:#sh license
Sat Dec 14 12:08:05.066 SCL
FeatureID: CRS-MSC-40G-IMP (Slot based, Implicit[Remaining time: unlimited])
  Total licenses 3
  Available for use         0
  Allocated to location     1
  Active                    2
  Store name             Permanent
  Store index               0
    Pool: Owner
      Total licenses in pool: 3
      Status: Available     0    Operational:    3
      Locations with licenses: (Active/Allocated) [SDR]
              0/5/CPU0        (1/0) [Owner]
              0/4/CPU0        (0/1) [Owner]
             0/3/CPU0        (1/0) [Owner]
FeatureID: XC-XLAT44-5M (Slot based, Permanent)
  Total licenses 1
  Available for use         1
  Allocated to location     0
  Active                    0
  Store index               1
    Pool: Owner
      Total licenses in pool: 1
      Status: Available     1    Operational:    0
I see that no activate.
somebody know this problem.
Thank
Ruben.
7 Replies 7
Rivalino Tamaela
Hello Ruben,
Is the CGN NAT configured and running already? License will be allocated and active once the feature is configured and running. Not sure with CGN NAT, but should be the same behavior I think.
regards,
rivalino
Hi Rivalino, I test with you say, but no see change in show.
my test.
ping from Edge to Internet (Edge-Core-Crs) ---->
the NAT is ok, the linecard generate the NAT. OK
But I don`t see that Licence is Active. same result that first show.
Thank.
somnathr
At present, CGN s/w does not grab the license.
As long as you've installed the license, you're fine.
Hi Somnath, I understand you request, if I have Licence for 5MM of traslation why I don`t Active Licence. how I safe me this operation is ok and not have  a problem in production.
Thank.
Hi Ruben,
You should not have any issue in production related to CGN/CGv6 license (CLI may not show the status correctly because of the reason I indicated earlier).
regards,
Somnath.
Hi Somnath, I have in production my CGN but yet I don't see that license be  active with traffic, you have some idea because  this.
RP/0/RP0/CPU0:#sh cgn nat44 NAT44 statistics
Wed Feb 26 11:53:09.010 SCL
Statistics summary of NAT44 instance: 'NAT44'
Number of active translations: 16845
Translations create rate: 67
Translations delete rate: 63
Inside to outside forward rate: 1982
Outside to inside forward rate: 2270
Inside to outside drops port limit exceeded: 0
Inside to outside drops system limit reached: 0
Inside to outside drops resorce depletion: 0
No translation entry drops: 830608
Pool address totally free: 0
Pool address used: 256
Wed Feb 26 12:48:57.034 SCL
  Total licenses 3
  Available for use         0
  Active                    2
  Store index               0
    Pool: Owner
  Total licenses 1
  Available for use         1
  Active                    0
  Store index               1
    Pool: Owner
Ruben.
Hi Ruben,
CGN licenses will not be shown as active for now. So, you can ignore the license state for now as long as you've installed the required licenses. It should not cause any issue on traffic.
regards,
Somnath.
