after NCS 5501-SE upgrade from 7.0.1 to 7.0.2 - UPGD FAIL status
from88
Level 4
Level 4
I upgraded new NCS5501-SE from 7.0.1 to 7.0.2 upgrade went smooth, but after doing last checks i see UPG-FAIL message is this something bad ?
RP/0/RP0/CPU0:ITXNCS01#show  hw-module fpd
Mon Jul 20 11:32:26.100 UTC
                                                               FPD Versions
Location   Card type             HWver FPD device       ATR Status   Running Programd
0/RP0      NCS-5501-SE           1.1   MB-MIFPGA            CURRENT    1.02    1.02
0/RP0      NCS-5501-SE           1.1   Bootloader           CURRENT    1.22    1.22
0/RP0      NCS-5501-SE           1.1   CPU-IOFPGA           UPGD FAIL  1.25    1.25
0/RP0      NCS-5501-SE           1.1   MB-IOFPGA            CURRENT    1.11    1.11
How to fix it ? Thanks.
As I rememeber in 7.0.1 there was no error like that.
When tryingto di it manualy: upgrade hw-module location all fpd all
Getting this error:
0/RP0/ADMIN0:Jul 20 12:41:55.420 UTC: card_mgr[3087]: %DRIVER-CARD_MGR-1-UPGD_SKIP : FPD upgrade skipped for CPU-IOFPGA @location 0/RP0 .The Bootloader primary or golden version on the box is not compatible with the new packaged CPU-IOFPGA. Kindly 'force' upgrade the Bootloader prior to manually upgrading CPU-IOFPGA to avoid bricking the board
is it safe to do it this upgrade hw-module location all fpd all force command, as log suggests ?
15 Replies 15
When you go to upgrade the router you can add the base packages and SMUs in the same command or multiple install add operations and then specify all the install IDs for each for install activate.
Sam
