05-31-2024 04:03 AM
I want to write in the event manager if the ping is not successful (Success rate is 0 percent), then you need to execute clear crypto ikev2 sa "x.x.x.x" Check available IP once every 3-5 minutes. Maybe someone will share the script.
05-31-2024 04:08 AM
you face issue with child SA ?
if Yes try ping from LAN to LAN, this make IKEv2 have always child SA
MHM
06-03-2024 05:38 AM
Check this https://github.com/leonmflai/Cisco-EEM-Auto-Export
