ASR 9000 BNG session limit issue
wilsonribeiro
Our CISCO is accepting only around 8300 subscriber pppoe connections.
It seems its some sort of session throttle, I'm getting lots of this:
LC/0/0/CPU0:Feb  8 21:01:47.126 : pppoe_ma[309]: [PADR-Recv]: TenGigE0/0/2/1.136 peer-
LC/0/0/CPU0:Feb  8 21:01:47.126 : pppoe_ma[309]: [PADR-Recv]:   DROPPED - session throttle or flow control
LC/0/0/CPU0:Feb  8 21:01:47.129 : pppoe_ma[309]: [PADR-Recv]: TenGigE0/0/2/1.101 peer-mac 1c7e.e5c5.ef4f
LC/0/0/CPU0:Feb  8 21:01:47.129 : pppoe_ma[309]: [PADR-Recv]:   DROPPED - session throttle or flow control
LC/0/0/CPU0:Feb  8 21:01:47.132 : pppoe_ma[309]: [PADR-Recv]: TenGigE0/0/2/1.97 peer-mac 84c9.b2de.4f6c
LC/0/0/CPU0:Feb  8 21:01:47.132 : pppoe_ma[309]: [PADR-Recv]:   DROPPED - session throttle or flow control
0/RSP0/CPU0
BBA-Group pppoegroup
MAC throttles not configured.
MAC-Access-interface throttles not configured.
MAC-IWF-Access-interface throttles not configured.
Circuit-ID throttles not configured.
Remote-ID throttles not configured.
Inner-VLAN-ID throttles not configured.
Outer-VLAN-ID throttles not configured.
Circuit-ID-and-Remote-ID throttles not configured.
0/0/CPU0
BBA-Grouppppoegroup
RP/0/RSP0/CPU0:ios#show interfaces tenGigE 0/0/2/1
Wed Feb  8 21:06:08.080 UTC
TenGigE0/0/2/1 is up, line protocol is up
  Interface state transitions: 1
  Hardware is TenGigE, address is 00c1.6463.0501 (bia 00c1.6463.0501)
  Layer 1 Transport Mode is LAN
  Internet address is Unknown
  MTU 1514 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, SR, link type is force-up
  output flow control is off, input flow control is off
Configured Access Interfaces
Ready                     599
Not-Ready                   0
TOTAL                     599
PPPoE Sessions
Complete                 9702
Incomplete                406
TOTAL                   10108
Flow Control
Limit                    2000
In Flight                1918
Dropped                363126
Disconnected            19472
Successful              15705
Can't see what could be limiting the connections.
Philip D'Ath
Do you mean it will be a limit of 8K because I'm shaping subscribers?
So the total sum of sessions on that MPA can NOT exceed 32k in a mod80. There is no per port limit. However if you have shaping QOS, you need to configure the QOS resources such as to where you need them on which port. Because the parent shapers are in 8k chunks, and if you have one interface with 10k sessions, you need to assign 2 chunks to that interface. This chunking stuff only applies to sessions that have shaping needs (policing not affected by this).
What would be "assign 2 chunks to that interface"?
