11-29-2017 01:27 AM - edited 03-01-2019 03:20 PM
I have a couple of switches with 40GE interfaces that I would like to connect to our Cisco ASR9K without using breakout cables.
I have been checking the list of ASR9K supported cards in this link
Inside this page there is a link with modular cards https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/data_sheet_c78-663866.html that seem to be the only ones with 40GE interfaces (A9K-MPA-1x40GE and A9K-MPA-2x40GE).
A couple of questions:
- Are these the only options with 40GE interfaces for ASR9K?
- Is it supported to split a 100GE interface into 2x40GE using CPAK-2X40G-LR4 or any other transceiver? This one I got it from a presentation, but I don't see it in the list CPAK transceiver modules
Thanks!
--Rafa
Solved! Go to Solution.
12-05-2017 10:24 AM
12-05-2017 10:24 AM
12-11-2017 04:26 AM
Thank you very much for your answer, Niko!
