12-06-2013 12:16 AM
Hi, we have a couple of ASR 9001.
The threshold value on our managment sytem for the temperature is 45 C.This value seems to be too low to me
Does anyone know the temperature threshold of the ASR 9001 Router?
I found nothing in the documents.
br, Peter
Solved! Go to Solution.
12-06-2013 08:07 AM
Hi Peter,
First number is minor
Second nubmer is major
Third is critical
Fourth is critical high
Fifth is system threshold (shutdown temp)
9001-RP
Inlet0 60, 63, 66, 69, 72
Inlet1 58, 60, 62, 64, 66
Hotspot0 68, 71, 73, 76, 78
Hotspot1 64, 70, 75, 81, 86
Hotspot2 71, 77, 82, 87, 92
Hotspot3 83, 85, 88, 92, 95
9001-LC
Hotspot0 71, 74, 76, 79, 81
Hotspot1 66, 69, 72, 75, 78
Hotspot2 70, 72, 75, 78, 81
Hotspot3 69, 72, 74, 77, 79
Hotspot4 73, 78, 82, 86, 90
Inlet0 65, 69, 73, 78, 82
Hotspot5 96, 98, 100, 102, 105
Hotspot6 96, 98, 100, 102, 105
HTH,
Sam
12-06-2013 07:22 AM
Hi Peter,
Operating temperature (nominal)
41 to 104ºF (5 to 40ºC)
(short-term)
23 to 131ºF (-5 to 55ºC)
HTH,
Sam
12-06-2013 07:38 AM
Hi Sam,
you misunderstand me.
What I am looking for is the threshhold for alarms.
like this example from a N5k
show environment temperature
Temperature
Module Sensor MajorThresh MinorThres CurTemp Status
(Celsius) (Celsius) (Celsius)
1 Outlet 67 58 47 ok
At which temperatur logs/sends the router the MinorThres alarm, and of course the MajorThresh alarm?
br, Peter
12-06-2013 08:07 AM
Hi Peter,
Third is critical
9001-RP
9001-LC
HTH,
Sam
12-06-2013 01:29 PM
Hi Sam thanks for your help
BR, Peter
Sent from Cisco Technical Support Android App
