ASR 9001 temperature threshold
pschueck
Hi, we have a couple of ASR 9001.
The threshold value on our managment sytem for the temperature is 45 C.This value seems to be too low to me
Does anyone know the temperature threshold of the ASR 9001 Router?
I found nothing in the documents.
br, Peter
Hi Peter,
First number is minor
Second nubmer is major
Third is critical
Fourth is critical high
Fifth is system threshold (shutdown temp)
9001-RP
Inlet0     60, 63, 66, 69, 72
Inlet1     58, 60, 62, 64, 66
Hotspot0   68, 71, 73, 76, 78
Hotspot1   64, 70, 75, 81, 86
Hotspot2   71, 77, 82, 87, 92
Hotspot3   83, 85, 88, 92, 95
9001-LC
Hotspot0  71, 74,  76,  79,  81
Hotspot1  66, 69,  72,  75,  78
Hotspot2  70, 72,  75,  78,  81
Hotspot3  69, 72,  74,  77,  79
Hotspot4  73, 78,  82,  86,  90
Inlet0    65, 69,  73,  78,  82
Hotspot5  96, 98, 100, 102, 105
Hotspot6  96, 98, 100, 102, 105
HTH,
Sam
smilstea
Hi Peter,
Operating temperature (nominal)
41 to 104ºF (5 to 40ºC)
(short-term)
23 to 131ºF (-5 to 55ºC)
http://www.cisco.com/en/US/prod/collateral/routers/ps9853/ps12074/data_sheet_c78-685687_ps9853_Products_Data_Sheet.html
HTH,
Sam
Hi Sam,
you misunderstand me.
What I am looking for is the threshhold for alarms.
like this example from a N5k
show environment temperature
Temperature
Module   Sensor     MajorThresh   MinorThres           CurTemp     Status
                              (Celsius)           (Celsius)              (Celsius)
1        Outlet             67                      58                     47                    ok
At which temperatur logs/sends the router the MinorThres alarm, and of course the MajorThresh alarm?
br, Peter
Hi Peter,
Third is critical
9001-RP
9001-LC
HTH,
Sam
pschueck
Hi Sam thanks for your help
BR, Peter
Sent from Cisco Technical Support Android App
