ASR 9010 licensing question
miro.siman
any good cisco reference for installing licenses for ASR 9010 router?
we need to "move" license to oper state
(admin)#sho license
Mon May 28 15:44:08.686 UTC
FeatureID: A9K-AIP-LIC-B (Slot based, Permanent)
  Total licenses 2
  Available for use         2
  Allocated to location     0
  Active                    0
  Store name             Permanent
  Store index               1
    Pool: Owner
      Total licenses in pool: 2
      Status: Available     2    Operational:    0
thanks for help
miro
5 Replies 5
Alexei Kiritchenko
Hello Miro,
Here you can find Software Entitlement on the Cisco ASR 9000 Series Router
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/system_management/configuration/guide/b_sysman_cg42asr9k_chapter_0101.html
you’d need to allocate a license to a slot you need.
For example:
RP/0/RSP0/CPU0:router(admin-config)# license A9K-AIP-LIC-B location 0/0/CPU0
Alex.
I have the same problem on asr 9001. A can't activate license regardless of the location.
(admin)#sh license
FeatureID: A9K-9001-AIP-LIC (Slot based, Permanent)
  Total licenses 1
  Available for use         1
  Active                    0
  Store index               1
    Pool: Owner
      Total licenses in pool: 1
      Status: Available     1    Operational:    0
license A9K-9001-AIP-LIC
 location 0/RSP0/CPU0
(admin)#sh platform
Wed Oct  1 14:45:47.427 CEST
Node            Type                      State            Config State
0/RSP0/CPU0     ASR9001-RP(Active)        IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP            ASR-9001-FAN-V2           READY
0/0/CPU0            ASR9001-LC                IOS XR RUN       PWR,NSHUT,MON
0/0/0                  A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/0/1                 A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0/PM0/SP        A9K-750W-AC               READY            PWR,NSHUT,MON
0/PM1/SP        A9K-750W-AC               FAILED           PWR,NSHUT,MON
Any suggestion?
Nenad
Hi Nenad,
This license is related to L3VPN functionality. Have you configured any L3VPN and associated any interface from desired location with that L3VPN VRF ?
I have seen this on ASR-9010; until you create an L3VPN VRF and associate a physical interface or a sub-interface to that VRF, the license doesn't move from available to allocated/active.
Please try and let us know if this helps
Br,
Anand
Hi anandbhalla,
thanks for reply, yes this license is related to L3VPN. I didn't configure because I though I need to activate license first. As soon as I try I'll get back result.
Regars,
Nenad
Anandbhalla,
you where right, I configured L3VPN and now license is active.
sh license:
  Total licenses 1
  Available for use         0
  Active                    1
  Store index               1
    Pool: Owner
      Status: Available     0    Operational:    1
      Locations with licenses: (Active/Allocated) [SDR]
              0/0/CPU0        (1/0) [Owner]
Best regards,
Nenad
