ASR 9910 code is not on CCO -- where can it be found ???
Junnie Sadler
On CCO there is the 9922, 9912, 9904 but not the 9910 code ??????????
Aleksandar Vidakovic
Hi Junnie,
The Software Download portal on CCO requires the chassis type to be listed, but for ASR9k this makes no difference because all asr9k platforms use the exact same binaries.
Which release are you looking for? If you are looking for 5.3.3, I would suggest to wait a couple of weeks and go for 5.3.4.
Are you deploying Service Packs on top of base release or you work with individual SMUs? In either case, you may want to use CSM (Cisco Software Manager) to help you manage the patches.
regards,
Aleksandar
Hi Aleksandar,
The RSP for the 9910 has a min. requirement of 6.0.1.
Florian
