ASR 9k BNG PPPOE Session Not Establish with CPAR Radius
Hi All,
I'm currently having an issue to establish PPPOE session that requires authentication using Cisco CPAR. I have followed the BNG Deployment Guide configuration, however I'm still unable to get the PPPOE session establish. Here some logs that I captured when connecting my pc and dialing:
#RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.014 WIB: pppoe_ma[392]: Bundle-Ether100.1699: I dst ffff.ffff.ffff src 00e0.4c8f.6b4a: len 46 0x110900000014010100000103000c08000000000000000f0000000000000000000000000000000000000000000000
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.014 WIB: pppoe_ma[392]: [PADI-Recv]: Bundle-Ether100.1699 peer-mac 00e0.4c8f.6b4a
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.014 WIB: pppoe_ma[392]: [PADI-Recv]: vlan-id-outer 1699
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.014 WIB: pppoe_ma[392]: [PADI-Recv]: Service-name:
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.014 WIB: pppoe_ma[392]: [PADI-Recv]: Host-uniq: 08000000000000000f000000
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.015 WIB: pppoe_ma[392]: Bundle-Ether100.1699: O dst 00e0.4c8f.6b4a src f87b.2072.60a3: len 55 0x110700000031010100000103000c08000000000000000f000000010200194a4b542d47414e44554c2d415352393030312d434e472d3031
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.015 WIB: pppoe_ma[392]: [PADO-Sent]: Bundle-Ether100.1699 peer-mac 00e0.4c8f.6b4a
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.015 WIB: pppoe_ma[392]: [PADO-Sent]: vlan-id-outer 1699
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: Bundle-Ether100.1699: I dst f87b.2072.60a3 src 00e0.4c8f.6b4a: len 46 0x111900000014010100000103000c0800000000000000100000000000000000000000000000000000000000000000
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: [PADR-Recv]: Bundle-Ether100.1699 peer-mac 00e0.4c8f.6b4a
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: [PADR-Recv]: vlan-id-outer 1699
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: [PADR-Recv]: Service-name:
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: [PADR-Recv]: Host-uniq: 080000000000000010000000
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699: Initializing new session
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.016 WIB: pppoe_ma[392]: Session: Creating and inserting a new session idb on parent interface Bundle-Ether100.1699, with session id 46
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.017 WIB: pppoe_ma[392]: Session: Successfully added new session idb to database of parent Bundle-Ether100.1699. Parent session IDB count = 1
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.017 WIB: pppoe_ma[392]: Session: Queuing interface create on parent interface Bundle-Ether100.1699, with session id 46
LC/0/0/CPU0:2023 Mar 10 15:59:44.119 WIB: pppoe_ea[310]: Interface: 0x00060760: Creating and inserting a new intf idb
LC/0/0/CPU0:2023 Mar 10 15:59:44.119 WIB: pppoe_ea[310]: Interface: 0x00060760: Successfully added new intf idb to database
LC/0/0/CPU0:2023 Mar 10 15:59:44.119 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF CREATE received
LC/0/0/CPU0:2023 Mar 10 15:59:44.119 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF CREATE(1), idb lookups/creates completed successfully
LC/0/0/CPU0:2023 Mar 10 15:59:44.123 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF CREATE(2), Hardware programming completed successfully
LC/0/0/CPU0:2023 Mar 10 15:59:44.123 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF CREATE(3), IMC interface create completed successfully
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.126 WIB: pppoe_ma[392]: Session: 0x00000000: Received interface create cb: No error
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.126 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699.pppoe46: Inserting a session idb into global database
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.126 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699.pppoe46: Successfully added new session idb to global database. Session IDB count = 1
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.127 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699.pppoe46: Received MTU notification, with MTU actual 1500
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.128 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Initial]: Up Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.128 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Initial]: Change to state Closed
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.128 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Down Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.128 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Change to state Initial
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.130 WIB: pppoe_ma[392]: Session: Received AAA batch start notication
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.130 WIB: pppoe_ma[392]: Session: Received AAA batch end notication
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.130 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699.pppoe46: Received AAA Session Create cb: No error
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.162 WIB: pppoe_ma[392]: Session: Received SubDB batch start notication
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.162 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699.pppoe46: Received Activate Config cb: No error
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.162 WIB: pppoe_ma[392]: Session: Received SubDB batch end notication
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: pppoe_ma[392]: Session: Bundle-Ether100.1699.pppoe46: Interface ready call succeeded
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Open Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: pppoe_ma[392]: [PADS-Sent]: Bundle-Ether100.1699 peer-mac 00e0.4c8f.6b4a
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Initialize-Restart-Counter
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: pppoe_ma[392]: [PADS-Sent]: vlan-id-outer 1699
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: O CONFREQ id 1 len 18
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: pppoe_ma[392]: Bundle-Ether100.1699: O dst 00e0.4c8f.6b4a src f87b.2072.60a3: len 26 0x1165002e0014010100000103000c080000000000000010000000
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: MRU 1492 (0x010405d4)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: AuthProto PAP (0x0304c023)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: MagicNumber 0x368ff7aa (0x0506368ff7aa)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.231 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Change to state Req-Sent
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.232 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: Open Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: I CONFREQ id 0 len 21
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: MRU 1480 (0x010405c8)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: MagicNumber 0x30506383 (0x050630506383)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: PFC (0x0702)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: ACFC (0x0802)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: Callback 6 (0x0d0306)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.252 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: O CONFREJ id 0 len 11
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: I CONFACK id 1 len 18
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: MRU 1492 (0x010405d4)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: AuthProto PAP (0x0304c023)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: MagicNumber 0x368ff7aa (0x0506368ff7aa)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: Initialize-Restart-Counter
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Req-Sent]: Change to state Ack-Rcvd
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Ack-Rcvd]: I CONFREQ id 1 len 14
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Ack-Rcvd]: MRU 1480 (0x010405c8)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Ack-Rcvd]: MagicNumber 0x30506383 (0x050630506383)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Ack-Rcvd]: O CONFACK id 1 len 14
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Ack-Rcvd]: Change to state Open
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: Report This-Layer-Up
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.297 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: Start authentication layer: PAP/<None> (of peer/of us)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: I IDENTIFY id 2 len 18 magic 0x30506383 MSRASV5.20
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: O CODEREJ id 2 len 22 code IDENTIFY
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: (0x0c020012305063834d5352415356352e)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: (0x3230)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: I IDENTIFY id 3 len 28 magic 0x30506383 MSRAS-0-NB5CD145HY5G
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: O CODEREJ id 3 len 32 code IDENTIFY
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: (0x0c03001c305063834d535241532d302d)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: (0x4e4235434431343548593547)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: I IDENTIFY id 4 len 24 magic 0x30506383 g^`i$g0OPLIW[zTQ
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: O CODEREJ id 4 len 28 code IDENTIFY
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: (0x0c04001830506383e79e606924e7304f)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.299 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: (0x900cc9171b7a1451)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.301 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: PAP: I REQUEST id 3 len 22 (from "test1234")
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.306 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: PAP: O NAK id 3 len 18 (msg "Access Denied")
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: PAP: Our authentication of peer failed: Peer's credentials are not acceptible
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: Close Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: Report This-Layer-Down (Closing)
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: Stop authentication layer
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: Initialize-Restart-Counter
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: O TERMREQ id 5 len 4
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.307 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Open]: Change to state Closing
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.309 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closing]: I TERMACK id 5 len 4
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.309 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closing]: Change to state Closed
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.309 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Report This-Layer-Finished
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.309 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Report Closed
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.309 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Close Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.319 WIB: pppoe_ma[392]: Bundle-Ether100.1699: I dst f87b.2072.60a3 src 00e0.4c8f.6b4a: len 46 0x11a7002e000000000000000000000000000000000000000000000000000000000000000000000000000000000000
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.319 WIB: pppoe_ma[392]: [PADT-Recv]: Bundle-Ether100.1699 peer-mac 00e0.4c8f.6b4a
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.319 WIB: pppoe_ma[392]: [PADT-Recv]: vlan-id-outer 1699
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.319 WIB: pppoe_ma[392]: Session: [ERROR] Bundle-Ether100.1699.pppoe46: Session being cleaned up, trigger 9
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.409 WIB: pppoe_ma[392]: Session: Received AAA batch start notication
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.409 WIB: pppoe_ma[392]: Session: Received AAA batch end notication
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.420 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Down Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.420 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Closed]: Change to state Initial
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.420 WIB: PPP-MA[391]: LCP: Bundle-Ether100.1699.pppoe46: [Initial]: Close Event
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.421 WIB: pppoe_ma[392]: Session: 0x00060760: Received FINAL notification
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.421 WIB: pppoe_ma[392]: Session: [ERROR] 0x00060760: Session being cleaned up, trigger 11
LC/0/0/CPU0:2023 Mar 10 15:59:44.428 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF DELETE received
LC/0/0/CPU0:2023 Mar 10 15:59:44.428 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF DELETE(1), idb lookups/creates completed successfully
LC/0/0/CPU0:2023 Mar 10 15:59:44.432 WIB: pppoe_ea[310]: Interface: 0x00060760: INTF DELETE(2), IMC interface delete completed successfully
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.433 WIB: pppoe_ma[392]: Session: 0x00060760: Interface delete completed successfully
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.433 WIB: pppoe_ma[392]: Session: 0x00000000: Successfully removed session idb from global database. Session IDB count = 0
RP/0/RSP0/CPU0:2023 Mar 10 15:59:44.433 WIB: pppoe_ma[392]: Session: 0x00000000: Successfully removed session idb from parent database. Parent session IDB count = 0
I have suspected the AAA configuration but not sure, because the existing IPoE method could work successfully using the same AAA server.
I attached my configuration for reference. Is there anyone can help me to point out if any missing config?
-Rp
where is config of radius server ??
there is some attribute must add to make radius know that this is IP or PPPoE
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU type 32
aaa radius attribute nas-port-id format NAS_PORT_FORMAT
aaa accounting subscriber default group radius
aaa authorization subscriber default group radius
aaa authentication subscriber default group radius
aaa attribute format MY_AUTH
mac-address plus circuit-id plus remote-id separator #
aaa attribute format NAS_PORT_FORMAT
circuit-id plus remote-id separator .
radius-server host <radius server> auth-port 1812 acct-port 1813
Hi Sir,
Here the snippet configuration of AAA:
aaa accounting exec default start-stop none
aaa group server radius RADIUS1
server <server-radius IP> auth-port 1812 acct-port 1813
aaa attribute format MAC
mac-address
aaa attribute format OPTION82
circuit-id
aaa authorization subscriber PPPOE group RADIUS1
aaa authentication subscriber PPPOE group RADIUS1
radius-server host <server-radius IP> auth-port 1812 acct-port 1813
