ASR 9K nv satellite status via snmp
Jacek Kupski
is it possible to monitor basic info of nv satellites via snmp? Which MIB do I have to use to accomplish that?
By basic info I mean:
- CPU, memory, environmental stats,
- status information etc.
Thanks.
Jacek Kupski
tkarnani
Hello Jacek,
Hope you are doing well. I looked into this internally for you.
It looks as if direct polling of the chassis for stats such as CPU,Memory is not supported at this time. Polling for CPU% for instance is not required because all the processing is done on the Host.
Thanks tkarnani,
what about checking info on satellite's sensors (for example, Rx optical power on SFP module with DOM; these information is accesible from the cli ) via snmp? Of course I'm polling ASR for that information, but for some reason I don't see any satellite sensors.
Jacek
