ASR 9K RSP-4G replacement question
pieterj
We have an ASR9K with a failed RSP running 4.2, gives intermittent memory error and then goes NSF not ready, after a while it goes nsf ready again. if I replace the card with one from our lab running older software (4.1), will the card auto upgrade when I plug it in or will I have to upgrade the card first before installing.
TIA
PJ
Vadim Zhovtanyuk
Hi PJ,
no, the new RSP will not be auto upgraded after installing.
You can upgrade the code in the lab before the replacement.
wbr
/vadim
thanks for the quick response, i searched but couldnt find any usefull info on cisco's website. I was hopfull that i wouldn't have to upgrade the box in the lab
what do people do when they have to RMA a card and the RMA arives on an older version of software if they dont have a spare to upgrade the software.
So I decided to give it a test and insert the card with the older software. The 9K automatically upgraded the software, as the card was inserted it booted into romon and then did an internal software upgrade from 127.0.1.4 via tftp download
Selecting ROMMON Image... B
DDR in Interleaved mode
POST 1 : PASSED : code 0 : DDR2 Memory Quick Test
CPU Reset Reason = 0x0005
POST 2 : PASSED : code 0 : FPGA Flash Image CRC Checks
Loading Field Programmable Devices:
FPGA 0-B PROGRAMMED  : image: 0xff500028 - 0xff576cca, et: 117ms
FPGA 1-B PROGRAMMED  : image: 0xff400028 - 0xff4d1034, et: 206ms
FPGA 2-B PROGRAMMED  : image: 0xff100028 - 0xff276358, et: 369ms
FPGA 3-B PROGRAMMED  : image: 0xff000028 - 0xff0454a8, et: 69ms
System Bootstrap, Version 1.04(20100216:021454) [ASR9K ROMMON],
Copyright (c) 1994-2010 by Cisco Systems, Inc.
Compiled Mon 15-Feb-10 18:14 by saurabja
  CPUCtrl:  1.17  [00000001/00000011]
  ClkCtrl:  1.18  [00000001/00000012]
  IntCtrl:  1.15  [00000001/0000000f]
     Punt:  1.5   [00000001/00000005]
      CBC:  1.2
      BID: 0x0006
PPC 8641D (partnum 0x0003), Revision 0.2, (Core Version 2.20080)
M8641 CLKIN:   66 Mhz
Core Clock: 1333 Mhz
  MPX Clock:  533 Mhz
  LBC Clock:   33 Mhz
POST 3 : PASSED : code 0 : Slot ID/Board Type Validity
PCI-E1: Ready as Root Complex
PCI-E2: Ready as Root Complex
set_chassis_type: chassis_type=0xef02fe found=TRUE
ASR9K (8641D PPC) platform with 4096 Mb of main memory
program load complete, entry point: 0x100000, size: 0x2ac20
MBI Candidate = disk0:asr9k-os-mbi-4.1.1/mbiasr9k-rp.vm
    CARD_SLOT_NUMBER: 5
        CPU_INSTANCE: 1
MBI Validation starts ...
Missing or illegal ip address for variable IP_ADDRESS
Mgt LAN 0 interface is selected
tsec_init_hw: configuring FE (port 2) for: Auto Speed, Auto Duplex
tsec_init_interface: hardware initialization completed
Interface link changed state to UP.
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
mbi_val_process_packet: received repsonse
Remote image to boot : tftp:/disk0/asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm
          IP_ADDRESS: 127.0.1.5
      IP_SUBNET_MASK: 255.255.0.0
     DEFAULT_GATEWAY: 127.0.1.4
         TFTP_SERVER: 127.0.1.4
           TFTP_FILE: /disk0/asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm
Performing tftpdnld
Receiving /disk0/asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm from 127.0.1.4 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
tftp_process_packet: last packet, block=42145, size=412.
File reception completed.
Image size=21578140, TFTP download size=21578140
program load complete, entry point: 0x201d9c, size: 0x149329c
Attempting to start second CPU
Config = SMP, Running = SMP
Board type: 0x00100302
Card Capability = 0xffffffff
BSP: Board type : RO-RSP2
tracelogger: starting tracing in background ring mode
tracelogger running with args: -startring -F 1 -F 2
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS XR Software for the Cisco XR ASR9K, Version 4.2.0
Copyright (c) 2011 by Cisco Systems, Inc.
Jun 04 13:17:44.492 : Install (Node Preparation): Initializing VS Distributor...
Jun 04 20:22:05.804 : Install (Node Preparation): Install device root from dSC is /disk0/
Jun 04 20:22:05.813 : Install (Node Preparation): Trying device disk0:
Jun 04 20:22:07.890 : Install (Node Preparation): Checking size of device disk0:
Jun 04 20:22:07.913 : Install (Node Preparation):    OK
Jun 04 20:22:07.917 : Install (Node Preparation): Cleaning packages on device disk0:
Jun 04 20:22:07.920 : Install (Node Preparation):    Please wait...
Jun 04 20:23:11.696 : Install (Node Preparation):    Complete
Jun 04 20:23:11.697 : Install (Node Preparation): Cleaning files on MBI device bootflash:
Jun 04 20:23:11.699 : Install (Node Preparation):    Please Wait...
Jun 04 20:23:12.527 : Install (Node Preparation):    Complete
Jun 04 20:23:12.530 : Install (Node Preparation): Checking free space on disk0:
Jun 04 20:23:12.532 : Install (Node Preparation):    OK
Jun 04 20:23:12.533 : Install (Node Preparation): Checking free space on MBI device bootflash:
Jun 04 20:23:12.535 : Install (Node Preparation):    OK
Jun 04 20:23:12.536 : Install (Node Preparation): Starting package and meta-data sync
Jun 04 20:23:12.553 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-k9sec-p-4.2.0
Jun 04 20:23:12.555 : Install (Node Preparation):    Please wait...
Jun 04 20:23:12.758 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-k9sec-p-4.2.0
Jun 04 20:23:12.760 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-k9sec-supp-4.2.0
Jun 04 20:23:12.762 : Install (Node Preparation):    Please wait...
Jun 04 20:23:13.072 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-k9sec-supp-4.2.0
Jun 04 20:23:13.074 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-security-4.2.0
Jun 04 20:23:13.076 : Install (Node Preparation):    Please wait...
Jun 04 20:23:17.265 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-security-4.2.0
Jun 04 20:23:17.268 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mpls-p-4.2.0
Jun 04 20:23:17.270 : Install (Node Preparation):    Please wait...
Jun 04 20:23:17.392 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mpls-p-4.2.0
Jun 04 20:23:17.394 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-mpls-4.2.0
Jun 04 20:23:17.396 : Install (Node Preparation):    Please wait...
Jun 04 20:23:24.204 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-mpls-4.2.0
Jun 04 20:23:24.207 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mini-p-4.2.0
Jun 04 20:23:24.209 : Install (Node Preparation):    Please wait...
Jun 04 20:23:25.224 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mini-p-4.2.0
Jun 04 20:23:25.226 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-ce-4.2.0
Jun 04 20:23:25.228 : Install (Node Preparation):    Please wait...
Jun 04 20:23:26.275 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-ce-4.2.0
Jun 04 20:23:26.277 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-fpd-4.2.0
Jun 04 20:23:26.279 : Install (Node Preparation):    Please wait...
Jun 04 20:25:55.616 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-fpd-4.2.0
Jun 04 20:25:55.619 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-cpp-4.2.0
Jun 04 20:25:55.621 : Install (Node Preparation):    Please wait...
Jun 04 20:26:22.884 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-cpp-4.2.0
Jun 04 20:26:22.888 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-scfclient-4.2.0
Jun 04 20:26:22.890 : Install (Node Preparation):    Please wait...
Jun 04 20:26:23.553 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-scfclient-4.2.0
Jun 04 20:26:23.555 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-diags-supp-4.2.0
Jun 04 20:26:23.557 : Install (Node Preparation):    Please wait...
Jun 04 20:26:24.525 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-diags-supp-4.2.0
Jun 04 20:26:24.527 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-fwding-4.2.0
Jun 04 20:26:24.529 : Install (Node Preparation):    Please wait...
Failed to rename debug file, 18, src: /nvram:/sysmgr.log.timeout.Z, target: /nvram:/prev.sysmgr.log.timeout.Z
Jun 04 20:26:55.306 : SYSMGR_LITE: Saving init logs in /nvram:/sysmgr.log.timeout.Z ...
Jun 04 20:27:14.721 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-fwding-4.2.0
Jun 04 20:27:14.729 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-base-4.2.0
Jun 04 20:27:14.731 : Install (Node Preparation):    Please wait...
Jun 04 20:27:46.927 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-base-4.2.0
Jun 04 20:27:46.936 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-os-mbi-4.2.0
Jun 04 20:27:46.938 : Install (Node Preparation):    Please wait...
Jun 04 20:27:59.760 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-os-mbi-4.2.0
Jun 04 20:27:59.762 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-ce-4.2.0
Jun 04 20:27:59.764 : Install (Node Preparation):    Please wait...
Jun 04 20:28:09.270 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-ce-4.2.0
Jun 04 20:28:09.273 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-diags-4.2.0
Jun 04 20:28:09.275 : Install (Node Preparation):    Please wait...
Jun 04 20:28:10.447 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-diags-4.2.0
Jun 04 20:28:10.450 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-routing-4.2.0
Jun 04 20:28:10.452 : Install (Node Preparation):    Please wait...
Jun 04 20:28:26.601 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-routing-4.2.0
Jun 04 20:28:26.605 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-fwding-4.2.0
Jun 04 20:28:26.607 : Install (Node Preparation):    Please wait...
Jun 04 20:30:31.150 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-fwding-4.2.0
Jun 04 20:30:31.187 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-infra-4.2.0
Jun 04 20:30:31.189 : Install (Node Preparation):    Please wait...
This (D)RP Node is not ready or active for login /configuration
Jun 04 20:32:35.139 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-infra-4.2.0
Jun 04 20:32:35.173 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-doc-p-4.2.0
Jun 04 20:32:35.175 : Install (Node Preparation):    Please wait...
Jun 04 20:32:35.411 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-doc-p-4.2.0
Jun 04 20:32:35.413 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9K-doc-supp-4.2.0
Jun 04 20:32:35.415 : Install (Node Preparation):    Please wait...
Jun 04 20:32:38.707 : Install (Node Preparation):    Completed syncing: /disk0/asr9K-doc-supp-4.2.0
Jun 04 20:32:38.709 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-services-p-4.2.0
Jun 04 20:32:38.711 : Install (Node Preparation):    Please wait...
Jun 04 20:32:38.970 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-services-p-4.2.0
Jun 04 20:32:38.972 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-service-supp-4.2.0
Jun 04 20:32:38.974 : Install (Node Preparation):    Please wait...
Jun 04 20:32:40.971 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-service-supp-4.2.0
Jun 04 20:32:40.973 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-service-4.2.0
Jun 04 20:32:40.975 : Install (Node Preparation):    Please wait...
Jun 04 20:32:44.691 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-service-4.2.0
Jun 04 20:32:44.694 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mgbl-p-4.2.0
Jun 04 20:32:44.696 : Install (Node Preparation):    Please wait...
Jun 04 20:32:44.876 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mgbl-p-4.2.0
Jun 04 20:32:44.878 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mgbl-supp-4.2.0
Jun 04 20:32:44.880 : Install (Node Preparation):    Please wait...
Jun 04 20:32:48.817 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mgbl-supp-4.2.0
Jun 04 20:32:48.820 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/iosxr-mgbl-4.2.0
Jun 04 20:32:48.822 : Install (Node Preparation):    Please wait...
Jun 04 20:32:56.480 : Install (Node Preparation):    Completed syncing: /disk0/iosxr-mgbl-4.2.0
Jun 04 20:32:56.483 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/instdb/ldpath
Jun 04 20:32:56.485 : Install (Node Preparation):    Please wait...
Jun 04 20:32:56.547 : Install (Node Preparation):    Completed syncing: /disk0/instdb/ldpath
Jun 04 20:32:56.549 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/instdb/ldpath.committed
Jun 04 20:32:56.551 : Install (Node Preparation):    Please wait...
Jun 04 20:32:56.608 : Install (Node Preparation):    Completed syncing: /disk0/instdb/ldpath.committed
Jun 04 20:32:56.610 : Install (Node Preparation): Completed sync of all packages and meta-data.
Jun 04 20:32:56.612 : Install (Node Preparation): Starting MBI sync
Jun 04 20:32:56.614 : Install (Node Preparation):    Please wait...
Jun 04 20:33:03.413 : Install (Node Preparation): Checking free space on /bootflash/
Jun 04 20:33:03.416 : Install (Node Preparation): Copying MBI from /disk0/asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm
Jun 04 20:33:03.417 : Install (Node Preparation): Copying MBI to /bootflash/disk0/asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm
Jun 04 20:33:58.465 : Install (Node Preparation): Completed sync of MBIs
Jun 04 20:33:58.510 : Install (Node Preparation): Operation completed successfully. This node will now reload from bootflash:.
Jun 04 20:33:58.513 : Install (Node Preparation):    Please wait...
Node 0/RSP1/CPU0: insthelper: self-reset to use new boot image ...
Spawning instdir_show_ltrace -r  failed. : No such file or directory
Spawning instdir_show_ltrace -Z -r failed. : No such file or directory
Spawning inst_rds_show_ltrace -r  failed. : No such file or directory
[0x171df1645b] Record Reboot History, reboot cause = 0x4000044, descr = Cause: self-reset to use new boot image                                       Process: insthelper                                                             Traceback: 4c2461b4 4c24rebooting
CPU Reset Reason = 0x000d
      CBC:  1.2
      BID: 0x0006
M8641 CLKIN:   66 Mhz
  MPX Clock:  533 Mhz
  LBC Clock:   33 Mhz
MBI Candidate = disk0:asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm
    CARD_SLOT_NUMBER: 5
        CPU_INSTANCE: 1
HIT CTRL-C to abort
Local image to boot : disk0:asr9k-os-mbi-4.2.0/0x100000/mbiasr9k-rp.vm
MBI size from header = 21578140,Bootflash resident MBI filesize = 21578140
           cisco Systems, Inc.
Jun 04 13:30:44.760 : Install (Node Preparation): Initializing VS Distributor...
Jun 04 20:35:07.096 : Install (Node Preparation): Install device root is /disk0/
Jun 04 20:35:07.108 : Install (Node Preparation): Trying device disk0:
Jun 04 20:35:11.156 : Install (Node Preparation): Checking size of device disk0:
Jun 04 20:35:11.163 : Install (Node Preparation):    OK
Jun 04 20:35:11.337 : Install (Node Preparation): Checking free space on disk0:
Jun 04 20:35:11.339 : Install (Node Preparation):    OK
Jun 04 20:35:11.341 : Install (Node Preparation): Checking free space on MBI device bootflash:
Jun 04 20:35:11.343 : Install (Node Preparation):    OK
Jun 04 20:35:11.344 : Install (Node Preparation): Starting package and meta-data sync
Jun 04 20:35:12.151 : Install (Node Preparation): Cleaning packages not in sync list
Jun 04 20:35:12.153 : Install (Node Preparation):    Please wait...
Jun 04 20:35:12.157 : Install (Node Preparation):    Complete
Jun 04 20:35:12.167 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-k9sec-p-4.2.0
Jun 04 20:35:12.169 : Install (Node Preparation):    Please wait...
Jun 04 20:35:12.545 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-k9sec-p-4.2.0
Jun 04 20:35:12.611 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mpls-p-4.2.0
Jun 04 20:35:12.613 : Install (Node Preparation):    Please wait...
Jun 04 20:35:12.904 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mpls-p-4.2.0
Jun 04 20:35:12.997 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mini-p-4.2.0
Jun 04 20:35:12.999 : Install (Node Preparation):    Please wait...
Jun 04 20:35:14.875 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mini-p-4.2.0
Jun 04 20:35:19.242 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-doc-p-4.2.0
Jun 04 20:35:19.244 : Install (Node Preparation):    Please wait...
Jun 04 20:35:19.598 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-doc-p-4.2.0
Jun 04 20:35:19.650 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-services-p-4.2.0
Jun 04 20:35:19.652 : Install (Node Preparation):    Please wait...
Jun 04 20:35:20.006 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-services-p-4.2.0
Jun 04 20:35:20.130 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/asr9k-mgbl-p-4.2.0
Jun 04 20:35:20.132 : Install (Node Preparation):    Please wait...
Jun 04 20:35:20.481 : Install (Node Preparation):    Completed syncing: /disk0/asr9k-mgbl-p-4.2.0
Jun 04 20:35:20.630 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/instdb/ldpath
Jun 04 20:35:20.632 : Install (Node Preparation):    Please wait...
Jun 04 20:35:20.694 : Install (Node Preparation):    Completed syncing: /disk0/instdb/ldpath
Jun 04 20:35:20.697 : Install (Node Preparation): Syncing package/meta-data contents: /disk0/instdb/ldpath.committed
Jun 04 20:35:20.699 : Install (Node Preparation):    Please wait...
Jun 04 20:35:20.761 : Install (Node Preparation):    Completed syncing: /disk0/instdb/ldpath.committed
Jun 04 20:35:20.762 : Install (Node Preparation): Completed sync of all packages and meta-data.
Jun 04 20:35:20.764 : Install (Node Preparation): Starting MBI sync
Jun 04 20:35:20.766 : Install (Node Preparation):    Please wait...
Jun 04 20:35:37.592 : Install (Node Preparation): Completed sync of MBIs
RP/0/RSP1/CPU0:Jun  4 20:36:33.102: syslogd_helper: [95]: dsc_event_handler: Got SysMgr dSC event : 16
RP/0/RSP1/CPU0:Jun  4 20:36:33.103: syslogd_helper: [95]: dsc_event_handler: syslogd_helper already received non DSC event 16
FPD ltrace_file_name => fpd-agent/fiarsp
cr1-NEW.alb con0/RSP1/CPU0 is in standby
FPD ltrace_file_name => fpd-agent/tempo
FPD ltrace_file_name => fpd-agent/longbeach
use. Delivery of Cisco cryptographic products does not imply third-party
authority to import, export, distribute or use encryption. Importers,
exporters, distributors and users are responsible for compliance with
U.S. and local country laws. By using this product you agree to comply
with applicable laws and regulations. If you are unable to comply with
U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be
found at:
export@cisco.com.
jstuxuhu0816
I think this should be upgrade automatically, since I know CRS-1 will upgrade automatically when u insert a new RSP with a different version from the active one.
Hu Xu
