ASR 9K SMU question
xzjleo2005
Hi guys, we want to install the SMU asr9k-p-4.2.0.CSCty91147.tar on our ASR 9k. After I install add it on ASR, when I typed install activate ?, I got  two items. But when I show intall inactive, only one iteam show up. My question is which one should I install activate, asr9K or iosxr? Thanks.
install activate ?
   disk0:asr9k-p-4.2.0.CSCty91147-1.0.0      Package to activate
  disk0:iosxr-infra-4.2.0.CSCty91147-1.0.0  Package to activate
show install inactive
Regards, Leo
Alexei Kiritchenko
Hello Leo,
asr9k-p-4.2.0.CSCty91147-1.0.0  is the name of the deployed SMU
iosxr-infra-4.2.0.CSCty91147-1.0.0  is the package inside the SMU.
One SMU may contain several packages, for example asr9k-p-4.2.0.CSCty98459 has 4 packages inside
    asr9k-fwding-4.2.0.CSCty98459
    asr9k-os-supp-4.2.0.CSCty98459
    asr9k-os-mbi-px-4.2.0.CSCty98459
    asr9k-base-4.2.0.CSCty98459
In your case, as there is only one package inside, you may use any name, but in general, as there may be several files to activate, use the main SMU name.
You can find the information on the SMU name and contained packages in the supplied txt file.
/A
Alexei Kiritchenko
Hello Leo,
/A
Hi Alex, thanks for your reply.
