Rommon HangUp C7200 VXR, Please help !!
madpeci72
I have C7200 Series VXR, manufacture 1997
I was press CPU RESET bottom
------------- PROBLEM --------------------
*** PUSH BUTTON NMI ***
  PC = 0xbfc0b960, SP = 0x80005db8, RA = 0xbfc0b990
CPU Registers:
ZERO = 0x00000000, AT = 0xfffffffe, V0 = 0xffffffff, V1 = 0xffffffff
  A0 = 0xa000203a, A1 = 0x00000080, A2 = 0x80005e0c, A3 = 0xa0002db0
  T0 = 0x80005d68, T1 = 0x00000002, T2 = 0xfffffffc, T3 = 0x00000003
  T4 = 0x20000000, T5 = 0xbfc326b4, T6 = 0x00000000, T7 = 0x3041d000
  S0 = 0x00000000, S1 = 0xa0000000, S2 = 0xa000203a, S3 = 0x0000007f
  S4 = 0xa000203a, S5 = 0x00000016, S6 = 0x00000008, S7 = 0x00000003
  T8 = 0x3041d001, T9 = 0xffffffff, K0 = <N/A>,      K1 = <N/A>
  GP = 0xffffffff, SP = 0x80005db8, S8 = 0x0000000a, RA = 0xbfc0b990
SREG = 0x3050d005, BADVADDR = 0xae015844, CAUSE = 0x00000000
EPC = 0xbfc0b990, ERR_EPC = 0xbfc0b960
System Return Info:
count: 19,  reason: reset
pc:0x6082ae2c,  error address: 0x0
Stack Trace:
FP: 0x00000000, PC: 0x00000000
C7200 platform with 524288 Kbytes of main memory
Please reset before booting
System Bootstrap, Version 12.2(4r)B4, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 2006 by cisco Systems, Inc.
rommon 1 >
After this prompt cannot type anything.
Any suggestion what should I do?
xthuijs
hard to say. I am afraid you have to open a tac case as we'll have to decide the stack traces to see what is going on.
When you open the case, make sure you include all the images relevant to this situation as that is needed to decode the traces.
you pressed the reset button and it reset, did you expect flowers?
xander
