ASR error
we get the following error repeatedly, what could be the reason ?
related to hardware issue ?
0/RP1/ADMIN0:Aug 4 09:00:33.685 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC0 in slot 0/RP0, error msg Device=CBC, reason=Power Sequencer fault
0/RP1/ADMIN0:Aug 4 08:59:36.499 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-7-CBC_POST_RESET_NOTIFICATION : Node 0/0 CBC-0, reset reason CPU_RESET_POR (0x05000000)
RP/0/RP1/CPU0:Aug 4 08:58:33.045 UTC: devc-conaux-aux_aux[124]: %MGBL-TTY-6-ISSU_NFN_REG : Registration for ISSU notification on STANDBY (tty_server_main), 0x0, 'Success' Successful
RP/0/RP1/CPU0:Aug 4 08:58:33.186 UTC: devc-conaux-con_con[113]: %MGBL-TTY-6-ISSU_NFN_REG : Registration for ISSU notification on STANDBY (tty_server_main), 0x0, 'Success' Successful
RP/0/RP1/CPU0:Aug 4 08:58:33.466 UTC: syslogd[436]: %SECURITY-XR_SSL-6-INFO : XR SSL info: Setting fips register
RP/0/RP1/CPU0:Aug 4 08:59:30.675 UTC: processmgr[51]: %OS-SYSMGR-7-DEBUG : node set to DSC
RP/0/RP1/CPU0:Aug 4 08:59:33.943 UTC: rmf_svr[197]: %PKT_INFRA-FM-2-FAULT_CRITICAL : ALARM_CRITICAL :RP-RED-LOST-PNP :DECLARE :0/RP1/CPU0:
RP/0/RP1/CPU0:Aug 4 08:59:33.943 UTC: rmf_svr[197]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :RP-RED-LOST-NNR :DECLARE :0/RP1/CPU0:
0/RP1/ADMIN0:Aug 4 08:59:38.477 UTC: shelf_mgr[3875]: %INFRA-SHELF_MGR-6-HW_EVENT : Rcvd HW event HW_EVENT_POWERED_OFF, event_reason_str 'HW Event Powered OFF' for card 0/0
0/RP1/ADMIN0:Aug 4 08:59:48.483 UTC: shelf_mgr[3875]: %INFRA-SHELF_MGR-6-HW_EVENT : Rcvd HW event HW_EVENT_POWERED_ON, event_reason_str 'HW Event Powered ON' for card 0/0
RP/0/RP1/CPU0:Aug 4 08:59:51.592 UTC: fib_mgr[169]: %PLATFORM-PLAT_FIB_RP-6-VPNV4_CONTEXT_INFO : initialization completed, tableID= 0x0, useSharedMemory= 1
RP/0/RP1/CPU0:Aug 4 08:59:51.645 UTC: fib_mgr[169]: %PLATFORM-PLAT_FIB_MPLS-6-CONTEXT_INFO : switch_gtrie intialization completed
RP/0/RP1/CPU0:Aug 4 08:59:51.648 UTC: fib_mgr[169]: %PLATFORM-PLAT_FIB_MPLS-6-CONTEXT_INFO : rej_gtrie intialization completed
RP/0/RP1/CPU0:Aug 4 08:59:51.701 UTC: fib_mgr[169]: %PLATFORM-PLAT_V6FIB_RP-6-VPNV6_CONTEXT_INFO : initialization completed, tableID= 0x0, useSharedMemory= 1
0/RP1/ADMIN0:Aug 4 08:59:54.574 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC0 in slot 0/RP0, error msg Device=CBC, reason=Power Sequencer fault
0/RP1/ADMIN0:Aug 4 08:59:55.163 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-6-INFO : slot 0/RP0, Device=CBC, reason=Boot up log - Power LED OFF
RP/0/RP1/CPU0:Aug 4 09:00:08.634 UTC: cepki[238]: %SECURITY-PKI-6-LOG_INFO_DETAIL : FIPS POST Successful for cepki
RP/0/RP1/CPU0:Aug 4 09:00:09.463 UTC: PPP-MA[254]: debug_register per_flow successful
RP/0/RP1/CPU0:Aug 4 09:00:10.381 UTC: rmf_svr[197]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :RP-RED-LOST-NSRNR :DECLARE :0/RP1/CPU0:
RP/0/RP1/CPU0:Aug 4 09:00:11.068 UTC: pim6[1209]: %ROUTING-IPV4_PIM-5-HA_NOTICE : NSR not ready
RP/0/RP1/CPU0:Aug 4 09:00:11.222 UTC: pim[1208]: %ROUTING-IPV4_PIM-5-HA_NOTICE : NSR not ready
RP/0/RP1/CPU0:Aug 4 09:00:11.334 UTC: ipsec_mp[381]: %SECURITY-IMP-6-PROC_READY : Process ipsec_mp is ready
RP/0/RP1/CPU0:Aug 4 09:00:11.788 UTC: cepki[238]: %SECURITY-CEPKI-6-KEY_INFO : One or more host keypairs exist. Not auto-generating keypairs.
0/RP1/ADMIN0:Aug 4 09:01:53.653 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-6-INFO : slot 0/RP0, Device=CBC, reason=Boot up log - Power LED OFF
0/RP1/ADMIN0:Aug 4 09:02:01.444 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-6-INFO : slot 0/0, Device=ROMMON, Code=Disk Boot
Watchdog Power Cycle: PEX:
0/RP1/ADMIN0:Aug 4 09:09:07.366 UTC: canbus_driver[3843]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC0 in slot 0/RP0, error msg Device=CBC, reason=Boot fail - Watchdog Power Cycle: PEX
here some license issues:
RP/0/RP1/CPU0:Aug 4 09:00:12.148 UTC: smartlicserver[132]: SMART_LIC-6-AGENT_ENABLED:Smart Agent for Licensing is enabled
RP/0/RP1/CPU0:Aug 4 09:00:12.148 UTC: smartlicserver[132]: SMART_LIC-6-EXPORT_CONTROLLED:Usage of export controlled features is not allowed
RP/0/RP1/CPU0:Aug 4 09:00:12.561 UTC: kim[156]: %INFRA-KIM-6-LOG_INFO : XR statistics will be pushed into the Linux kernel at 1 second intervals
RP/0/RP1/CPU0:Aug 4 09:00:14.528 UTC: smartlicserver[132]: SMART_LIC-6-EXPORT_CONTROLLED:Usage of export controlled features is allowed
RP/0/RP1/CPU0:Aug 4 09:00:14.529 UTC: smartlicserver[132]: SMART_LIC-6-HA_ROLE_CHANGED:Smart Agent HA role changed to Active.
Boris
tkarnani
Power sequencer faults are usually hardware faults.
we can try physically re-seating this card. an enhancement was made to try to recover via software if possible
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux24553/?rfs=iqvred
but if it does not recover after a hard re-seat, we would need to replace it
tkarnani
Vijesh sahani
