ASR SMUs installation error during installation of 7.9.21
hello experts
i am performing the software upgrade on ASR9904 using usb-boot method after the installation I try to install few SMUs that failed as following:
RP/0/RSP0/CPU0:E-JUB-ASE-C-N540-MUTF-01#
RP/0/RSP0/CPU0:E-JUB-ASE-C-N540-MUTF-01#install activate asr9k-gcp-fwding-64-1$
Sun Aug 11 17:35:20.792 AST
2024-08-11 17:35:22 Install operation 44 started by root:
install activate pkg asr9k-gcp-fwding-64-1.0.0.3-r7921.CSCwj24096 asr9k-os-supp-64-1.0.0.1-r7921.CSCwi65218 asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032 asr9k-gcp-fwding-64-1.0.0.4-r7921.CSCwj26267 asr9k-base-64-1.0.0.2-r7921.CSCwi65218 asr9k-fwding-64-1.0.0.4-r7921.CSCwf47611 asr9k-gcp-fwding-64-1.0.0.7-r7921.CSCwj87115 synchronous
2024-08-11 17:35:22 Package list:
2024-08-11 17:35:22 asr9k-gcp-fwding-64-1.0.0.3-r7921.CSCwj24096
2024-08-11 17:35:22 asr9k-os-supp-64-1.0.0.1-r7921.CSCwi65218
2024-08-11 17:35:22 asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032
2024-08-11 17:35:22 asr9k-gcp-fwding-64-1.0.0.4-r7921.CSCwj26267
2024-08-11 17:35:22 asr9k-base-64-1.0.0.2-r7921.CSCwi65218
2024-08-11 17:35:22 asr9k-fwding-64-1.0.0.4-r7921.CSCwf47611
2024-08-11 17:35:22 asr9k-gcp-fwding-64-1.0.0.7-r7921.CSCwj87115
2024-08-11 17:35:31 Action 1: install prepare action started
2024-08-11 17:36:06 The prepared software is set to be activated with system reboot
2024-08-11 17:36:15 ERROR: Package Compatibility Check Failed.
ERROR: Package asr9k-gcp-fwding-64-1.0.0.3-r7921.CSCwj24096.x86_64 requires asr9k-common-pd-fib-64 of version = 1.0.0.1 which is not present in the system
Please install all pre-requisites for asr9k-gcp-fwding-64-1.0.0.3-r7921.CSCwj24096.x86_64
2024-08-11 17:36:15 Action 1: install prepare action aborted
2024-08-11 17:36:15 ERROR!! failed while complete prepare checks on packages
2024-08-11 17:36:16 Install operation 44 aborted
2024-08-11 17:36:16 Ending operation 44
RP/0/RSP0/CPU0:Aug 11 17:36:16.909 AST: sdr_instmgr[1339]: %INSTALL-INSTMGR-3-OPERATION_ABORT : Install operation 44 aborted
Could you please help me know how to fix it.
thank you
3 Accepted Solutions
Giuseppe Larosa
Hello @sajid.muhammad54 ,
the error message says whay you need to do:
you need to install the following component:
Hope to help
Giuseppe
SMU CSCwi01353 is a pre-requisite.
Sam
The tar file with the SMU itself should have a readme file with the requirements.
For the first one:
Pre-requisite:
asr9k-x64-7.9.21.CSCwj33769
asr9k-x64-7.9.21.CSCwi01353
For the second:
Pre-requisite:
So same pre-requisites.
Sam
7 Replies 7
Giuseppe Larosa
Hope to help
Giuseppe
Hello Giuseppe,
inside the ASR9K-x64-iosxr-px-k9-7.9.21.tar file I could not find the asr9k-common-pd-fib-64 package file and after installing the ASR9K-x64-iosxr-px-k9-7.9.21.tar file I have only below packages available those required to activate.
asr9k-xr-7.9.21 version=7.9.21 [Boot image]
asr9k-optic-x64-1.0.0.0-r7921
asr9k-bng-x64-1.0.0.0-r7921
asr9k-k9sec-x64-1.0.0.0-r7921
asr9k-9000v-nV-x64-1.0.0.0-r7921
asr9k-bng-ipoe-x64-1.0.0.0-r7921
asr9k-bng-pppoe-x64-1.0.0.0-r7921
asr9k-eigrp-x64-1.0.0.0-r7921
asr9k-isis-x64-1.0.0.0-r7921
asr9k-li-x64-1.0.0.0-r7921
asr9k-m2m-x64-1.0.0.0-r7921
asr9k-mpls-x64-1.0.0.0-r7921
asr9k-bng-supp-x64-1.0.0.0-r7921
asr9k-mgbl-x64-1.0.0.0-r7921
asr9k-mcast-x64-1.0.0.0-r7921
asr9k-ospf-x64-1.0.0.0-r7921
asr9k-services-x64-1.0.0.0-r7921
asr9k-mpls-te-rsvp-x64-1.0.0.0-r7921
Sam
Hello Sam,
Thanks some of the SMUs are installed after installing the  CSCwi01353 but some of them are having still issues to activate
 1#show install inactive
Tue Aug 13 16:17:54.802 AST
4 inactive package(s) found:
error is below  even though I have installed the pre-req CSCwh77032
2024-08-13 16:16:19 Install operation 85 started by root:
install activate pkg asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032 force synchronous
2024-08-13 16:16:19 Package list:
2024-08-13 16:16:19 asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032
2024-08-13 16:16:19 Warning: 'force' option has been disabled. Install will perform package compatibility check
2024-08-13 16:16:25 Action 1: install prepare action started
2024-08-13 16:16:38 The prepared software is set to be activated with system reboot
2024-08-13 16:16:47 ERROR: Package Compatibility Check Failed.
ERROR: Package asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032.x86_64 requires asr9k-fwding-64 of version = 1.0.0.6 which is not present in the system
Please install all pre-requisites for asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032.x86_64
2024-08-13 16:16:47 Action 1: install prepare action aborted
2024-08-13 16:16:47 ERROR!! failed while complete prepare checks on packages
Hello Sam,
I am having an issue with activating the last 2 SMUs, could you please help out here with the required prerequisites for this?
Thanks.
#sh install inactive
Tue Aug 13 17:40:40.103 AST
2 inactive package(s) found:
RP/0/RSP0/CPU0:#install activate asr9k-gcp-fwding-64-1$
Tue Aug 13 17:40:56.473 AST
2024-08-13 17:40:58 Install operation 111 started by root:
2024-08-13 17:40:58 Package list:
2024-08-13 17:40:58 asr9k-gcp-fwding-64-1.0.0.6-r7921.CSCwh77032
2024-08-13 17:41:23 Install operation 111 aborted
RP/0/RSP0/CPU0:Aug 13 17:41:23.934 AST: sdr_instmgr[1339]: %INSTALL-INSTMGR-3-OPERATION_ABORT : Install operation 111 aborted
RP/0/RSP0/CPU0:E-JUB-ASE-C-N540-MUTF-01#show install log reverse
Tue Aug 13 17:42:43.845 AST
2024-08-13 17:41:04 Action 1: install prepare action started
2024-08-13 17:41:14 The prepared software is set to be activated with system reboot
2024-08-13 17:41:22 ERROR: Package Compatibility Check Failed.
2024-08-13 17:41:22 Action 1: install prepare action aborted
2024-08-13 17:41:22 ERROR!! failed while complete prepare checks on packages
2024-08-13 17:41:23 Ending operation 111
2024-08-13 17:21:30 Install operation 110 started by root:
install activate pkg asr9k-gcp-fwding-64-1.0.0.7-r7921.CSCwj87115 force synchronous
2024-08-13 17:21:30 Package list:
2024-08-13 17:21:30 asr9k-gcp-fwding-64-1.0.0.7-r7921.CSCwj87115
2024-08-13 17:21:30 Warning: 'force' option has been disabled. Install will perform package compatibility check
2024-08-13 17:21:36 Action 1: install prepare action started
2024-08-13 17:21:49 The prepared software is set to be activated with system reboot
2024-08-13 17:21:58 ERROR: Package Compatibility Check Failed.
For the first one:
Pre-requisite:
For the second:
Pre-requisite:
Sam
Thanks Sam for your great support
