09-14-2013 12:47 PM
Hello Guys,
On a PPPoE setup, and in a authentication-failure event (after a access-reject from Radius) can i still assign a IP address and redirect the subscriber to a Web server?
I only see examples for IP subscribers, so i am lost here. Can someone tell me if this is possible?
Thanks!
David
09-14-2013 01:05 PM
My idea (only on paper for now) is to apply a dynamic-template similar to the one applied on session-start and session-activate, use the regular ip address pool but include an ACL limiting access to the Web Server. Then in the same dynamic-template apply a PBR policy-map redirecting to the web server.
Will this work?
09-17-2013 02:11 PM
hi david, my recommendation is to make a particular dynamic template and define a specific (non routable) pool and assign it to the template
on auth failure activate that template for address assignment and apply the http-r
or you can use your global pool also, so that if they pay their bill you can remove http-r and have them running happily.
xander
