ASR9000-BNG Sessions PPPoE does not work - Client Sending PADT
juanchop246
Hi Everyone
I got an error trying to establish a pppoe session to a BNG ASR9000, in the debug it seems that que client pppoe its sending a pppoe packet type 11a7 (PADT) to the BNG, just after the client receives a pppoe packet type 1165 (PADS). I just already checked several debugs in the ASR9000 but i couldn't see the reason for this behavior.
Maybe if somebody could guide me, i´ll  appreciate a lot.
Thanks in advance.
Regards.
Configuration:
dynamic-template
type ppp PPP_ERT
ppp authentication chap
ppp ipcp peer-address pool PPPoE
ipv4 unnumbered Loopback1000
interface GigabitEthernet0/0/0/15.2
service-policy type control subscriber PPP_PM
pppoe enable bba-group ERT
encapsulation dot1q 2
aaa accounting subscriber default group radius
aaa authorization subscriber default group radius
aaa authentication subscriber default group radius
pppoe bba-group ERT
service selection disable
class-map type control subscriber match-any PPP
match protocol ppp
end-class-map
policy-map type control subscriber PPP_PM
event session-start match-first
class type control subscriber PPP do-until-failure
10 activate dynamic-template PPP_ERT
event session-activate match-first
10 authenticate aaa list default
Debug pppoe packets
debug pppoe all
LC/0/0/CPU0:May 21 12:05:19.947 : pppoe_ea[307]: Created table entry(s) for index0, session index 0xc, sub-parent's uidb index 0x17, entry count 1.
LC/0/0/CPU0:May 21 12:05:19.947 : pppoe_ea[307]: Set resource consumption to 3 for batch
LC/0/0/CPU0:May 21 12:05:19.947 : pppoe_ea[307]: Program session table for batch COMPLETE, sending the last msg, index0.
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: Stored session ID 12 parent uidb index 0X17 for interface 0x40009c0
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: Set resource consumption to 4 for batch
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: Freeing TCAM info
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: Interface 0x40009c0 marked as clean
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: No rollback required - all interfaces created successfully
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: Interface: 0x040009c0: INTF CREATE(2), Hardware programming completed successfully
LC/0/0/CPU0:May 21 12:05:19.948 : pppoe_ea[307]: Interface: 0x040009c0: INTF CREATE(3), IMC interface create completed successfully
LC/0/0/CPU0:May 21 12:05:19.955 : pppoe_ma[308]: Session: 0x00000000: Received interface create cb: No error
LC/0/0/CPU0:May 21 12:05:19.955 : pppoe_ma[308]: Session: GigabitEthernet0/0/0/15.2.pppoe12: Inserting a session idb into global database
LC/0/0/CPU0:May 21 12:05:19.955 : pppoe_ma[308]: Session: GigabitEthernet0/0/0/15.2.pppoe12: Successfully added new session idb to global database. Session IDB count = 1
LC/0/0/CPU0:May 21 12:05:19.956 : pppoe_ma[308]: Session: GigabitEthernet0/0/0/15.2.pppoe12: Received MTU notification, with MTU actual 1500
LC/0/0/CPU0:May 21 12:05:19.969 : pppoe_ma[308]: Session: Received AAA batch start notication
LC/0/0/CPU0:May 21 12:05:19.969 : pppoe_ma[308]: Session: GigabitEthernet0/0/0/15.2.pppoe12: Received AAA Session Create cb: No error
LC/0/0/CPU0:May 21 12:05:19.970 : pppoe_ma[308]: Session: Received AAA batch end notication
LC/0/0/CPU0:May 21 12:05:20.011 : pppoe_ma[308]: Session: Received SubDB batch start notication
LC/0/0/CPU0:May 21 12:05:20.011 : pppoe_ma[308]: Session: GigabitEthernet0/0/0/15.2.pppoe12: Received Activate Config cb: No error
LC/0/0/CPU0:May 21 12:05:20.012 : pppoe_ma[308]: Session: Received SubDB batch end notication
LC/0/0/CPU0:May 21 12:05:20.070 : pppoe_ma[308]: Session: GigabitEthernet0/0/0/15.2.pppoe12: Interface ready call succeeded
LC/0/0/CPU0:May 21 12:05:20.070 : pppoe_ma[308]: [PADS-Sent]: GigabitEthernet0/0/0/15.2 peer-mac ac87.a334.e459
LC/0/0/CPU0:May 21 12:05:20.070 : pppoe_ma[308]: [PADS-Sent]: vlan-id-outer 2
LC/0/0/CPU0:May 21 12:05:20.070 : pppoe_ma[308]: GigabitEthernet0/0/0/15.2: O dst ac87.a334.e459 src 40ce.241b.c3f7: len 22 0x1165000c0010010100000103000800f86c1f80ffffff
LC/0/0/CPU0:May 21 12:05:53.150 : pppoe_ma[308]: GigabitEthernet0/0/0/15.2: I dst 40ce.241b.c3f7 src ac87.a334.e459: len 46 0x11a7000c000000000000000000000000000000000000000000000000000000000000000000000000000000000000
LC/0/0/CPU0:May 21 12:05:53.150 : pppoe_ma[308]: [PADT-Recv]: GigabitEthernet0/0/0/15.2 peer-mac ac87.a334.e459
LC/0/0/CPU0:May 21 12:05:53.150 : pppoe_ma[308]: [PADT-Recv]: vlan-id-outer 2
LC/0/0/CPU0:May 21 12:05:53.150 : pppoe_ma[308]: Session: [ERROR] GigabitEthernet0/0/0/15.2.pppoe12: Session being cleaned up, trigger 9
LC/0/0/CPU0:May 21 12:05:53.250 : pppoe_ma[308]: Session: Received AAA batch start notication
LC/0/0/CPU0:May 21 12:05:53.250 : pppoe_ma[308]: Session: Received AAA batch end notication
LC/0/0/CPU0:May 21 12:05:53.258 : pppoe_ma[308]: Session: 0x040009c0: Received FINAL notification
LC/0/0/CPU0:May 21 12:05:53.258 : pppoe_ma[308]: Session: [ERROR] 0x040009c0: Session being cleaned up, trigger 11
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Interface: 0x040009c0: INTF DELETE received
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Interface: 0x040009c0: INTF DELETE(1), idb lookups/creates completed successfully
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Need a total of 1 TCAM indexes
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Need 1 TCAM indexes for NP #0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Allocated memory to hold 1 TCAM indexes for NP #0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Built list of 1 TCAM indexes for NP #0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Freeing 1 TCAMs for NP #0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Freed 1 TCAMs for NP #0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Found tcam index 0x4 for index0 on np 0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: Session Table Build For Intf: For delete, subscriber session data 12, parent uidb data 23, result No error (0x0)
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: PRM Hw key entry 0 = 0x0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: PRM Hw key entry 1 = 0x17
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: PRM Hw key entry 2 = 0x0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: PRM Hw key entry 3 = 0x0
LC/0/0/CPU0:May 21 12:05:53.262 : pppoe_ea[307]: PRM Hw key entry 4 = 0xC
LC/0/0/CPU0:May 21 12:05:53.263 : pppoe_ea[307]: PRM Hw key entry 5 = 0x0
LC/0/0/CPU0:May 21 12:05:53.263 : pppoe_ea[307]: Created table entry(s) for index0, session index 0xc, sub-parent's uidb index 0x17, entry count 1.
LC/0/0/CPU0:May 21 12:05:53.263 : pppoe_ea[307]: Free session table for batch COMPLETE, sending the last msg, index0.
LC/0/0/CPU0:May 21 12:05:53.264 : pppoe_ea[307]: Deleting uIDBs for 1 interfaces
LC/0/0/CPU0:May 21 12:05:53.266 : pppoe_ea[307]: Freeing TCAM info
LC/0/0/CPU0:May 21 12:05:53.266 : pppoe_ea[307]: Interface: 0x040009c0: INTF DELETE(2), IMC interface delete completed successfully
LC/0/0/CPU0:May 21 12:05:53.267 : pppoe_ma[308]: Session: 0x040009c0: Interface delete completed successfully
LC/0/0/CPU0:May 21 12:05:53.267 : pppoe_ma[308]: Session: 0x00000000: Successfully removed session idb from global database. Session IDB count = 0
LC/0/0/CPU0:May 21 12:05:53.267 : pppoe_ma[308]: Session: 0x00000000: Successfully removed session idb from parent database. Parent session IDB count = 0
AlanGregory
Did you set an ip address on Loopback 1000?
xthuijs
this is probably not the complete pppoe debugging log right?
I am missing the PADI reception and the PADO from the router sent and the PADR confirmation from the client.
what does stand out is that the PADS was sent upon which after 30 seconds a PADT is received.
it smells to me that the client never received the PADS in that case.
after PADS for the BNG, it would start to send LCP confreq messages, it looks like the client is not seeing any of that.
debug pppoe protocol debug pppoe packet is helpful
as well as debug ppp nego
if the client has some debugging capabilities, seeing some logs from that end would be helpful also.
confirm with a wireshark that the messages are hitting the line too.
also since you are using LC based subscribers make sure your release in question is adequate to support that.
regards
xander
