02-28-2020 07:33 AM
hello
we have an ASR 9010 have only 1 RSP440 installed, and we want to install RSP880 instead.
i read on a document thats its prerequisite to have 2 RSP440 installed acting as Active/standby.
what happen in my case how should i migrate whats the procedure for that?
and what happen to the current configuration?
note the current XR ver 5.1.2
02-28-2020 09:03 AM
You would need a higher release that support RSP880 in order to follow this guide:
Otherwise you could pre-stage the RSP880s in lab and then power down router and replace the RSPs.
Sam
02-28-2020 09:11 AM
02-28-2020 09:53 AM
Yes, the minimum for RSP880 at all is 5.3.0 but for the live migration is 5.3.2.
Sam
