ASR9000v with gigabit ICL
jerome.gomez
i have a lab with an ASR9006 and 2 ASR9000v (find below part list).
Both Satellites work well on 10G bundle ICL (find below configuation). So they are up to date regarding the 9006 (IOS XR 5.3.1)
When i try to use one of them with Giga ICL (support confirmed by Cisco) i have a strange behavior. Is there something special for Gig ICL wich i forgot ?
Port on Sat is coming up
LC:Satellite# sh int ten 1/46
TenGigabitEthernet1/46 is up, line protocol is up
but not on ASR 9006
RP/0/RSP0/CPU0:ios#sh int gig 0/2/0/0
Thu Sep 24 01:57:38.021 UTC
GigabitEthernet0/2/0/0 is up, line protocol is down
so bundle don't come up
Bundle-Ether200
  Status:                                    Down
as a  consequence sat discovery is stalled
RP/0/RSP0/CPU0:ios#sh nv satellite status
Thu Sep 24 01:54:29.668 UTC
Satellite 100
  Status: Connected (Stable)
  Type: asr9000v2
  Description: test 1
  MAC address: removed
  IPv4 address: 192.168.0.100 (VRF: default)
  Serial Number: removed
  Remote version: Compatible (latest version)
    ROMMON: 127.1 (Latest)
    FPGA: 1.13 (Latest)
    IOS: 531.101 (Latest)
  Configured satellite fabric links:
    Bundle-Ether100
      Status: Satellite Ready
      Remote ports: GigabitEthernet0/0/0-43
      Discovered satellite fabric links:
        TenGigE0/1/0/1: Satellite Ready; No conflict
Satellite 200
  Status: Discovery Stalled; Conflict: interface is down
  Type: asr9000v2
  Description: test 2
  IPv4 address: 192.168.0.200 (VRF: default)
    Bundle-Ether200
        GigabitEthernet0/2/0/0: Discovery Stalled; interface is down
RP/0/RSP0/CPU0:ios#
note : i tried several changes without improvment
  • patchcord
  • SFPs
  • Ports and cards on ASR 9006
  • ICL port on Sat (from 45 to 48 even if 47 and 48 are not supported for Gig ICL)
  • Sat
  • remove bundle config to use a single link
Thanks for your help :)
appendices
sh inventory extract
Thu Sep 24 02:15:13.030 UTC
NAME: "module 0/RSP0/CPU0", DESCR: "ASR9K Route Switch Processor with 440G/slot Fabric and 12GB"
NAME: "module 0/RSP1/CPU0", DESCR: "ASR9K Route Switch Processor with 440G/slot Fabric and 12GB"
NAME: "module 0/0/CPU0", DESCR: "80G Modular Linecard, Service Edge Optimized"
NAME: "module 0/0/0", DESCR: "ASR 9000 20-port 1GE Modular Port Adapter"
NAME: "module 0/1/CPU0", DESCR: "80G Modular Linecard, Packet Transport Optimized"
NAME: "module 0/1/0", DESCR: "ASR 9000 4-port 10GE Modular Port Adapter"
NAME: "module mau 0/1/0/0", DESCR: "Multirate 10GBASE-LR and OC-192/STM-64 SR-1 XFP, SMF"
NAME: "module mau 0/1/0/1", DESCR: "Multirate 10GBASE-LR and OC-192/STM-64 SR-1 XFP, SMF"
NAME: "module mau 0/1/0/3", DESCR: "DWDM Tunable Wavelength XFP, Channel 1 to 82"
NAME: "module 0/2/CPU0", DESCR: "80G Modular Linecard, Service Edge Optimized"
NAME: "module 0/2/0", DESCR: "ASR 9000 20-port 1GE Modular Port Adapter"
NAME: "module mau 0/2/0/0", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
NAME: "module mau 0/2/0/7", DESCR: "10GBASE-SR SFP+ Module for MMF"
NAME: "module mau 0/2/0/8", DESCR: "GE T"
NAME: "module mau 0/2/0/18", DESCR: "1000BASE-SX SFP transceiver module, MMF, 850nm, DOM"
NAME: "module mau 0/2/0/19", DESCR: "1000BASE-SX SFP transceiver module, MMF, 850nm, DOM"
NAME: "module 0/2/1", DESCR: "ASR 9000 20-port 1GE Modular Port Adapter"
NAME: "module mau 0/2/1/0", DESCR: "1000BASE-BX SFP, 1490NM"
NAME: "module mau 0/2/1/2", DESCR: "1000BASE-BX SFP, 1310NM"
NAME: "module mau 0/2/1/6", DESCR: "1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM"
sh run extract
nv
 satellite 100
  type asr9000v2
  ip address 192.168.0.100
  description test 1
 satellite 200
  type asr9000v2
  ip address 192.168.0.200
  description test 2
interface Bundle-Ether100
 ipv4 point-to-point
 ipv4 unnumbered Loopback1000
 nv
  satellite-fabric-link satellite 100
   remote-ports GigabitEthernet 0/0/0-43
interface Bundle-Ether200
 ipv4 point-to-point
 nv
  satellite-fabric-link satellite 200
interface Loopback1000
 ipv4 address 192.168.0.1 255.255.255.255
interface GigabitEthernet0/2/0/0
 bundle id 200 mode on
interface TenGigE0/1/0/1
 bundle id 100 mode on
6 Replies 6
smilstea
Do you have both bundles configured at the same time?
Sounds like you are trying to do a L1 topology, which supports partitioning, but your config has both bundles trying to get all the access ports.
Can you try changing the port assignment or only having one of the bundles configured?
Sam
Hi Sam, thanks for your quick answer
not sure to well understand what you mean
yes i try to use both bundles at the same time (with two different ASR 9000v)
To be clear on my config, i try to have 2 bundles (1 for each Satelite).
Bundle 100 for Sat 100 whitch is a first 9000V
Bundle 200 for Sat 200 whitch is a second 9000V
This conf is working when i use 10Gig ICL for both sat
When use the bundle 200 with Giga ports (no more 10G in this one) i have the depicted behavior.
Ahh, I see that now.
Can you connect the 10G back to satellite 200 and make sure the satellite is updated to the latest revision?
Also having the show im database interface gig 0/2/0/0 and debug nv satellite internal dpm all interface gig 0/2/0/0 verbose will help from both the working and non-working conditions.
Sam
Sat 200 was connected in 10 and was working well with remote version [Compatible (latest version)]
I done it to be sure that the version in SAT is compliant with Gig ICL :)
RP/0/RSP0/CPU0:ios#show im database interface gig 0/2/0/0
Thu Sep 24 06:13:16.242 UTC
View: OWN - Owner, L3P - Local 3rd Party, G3P - Global 3rd Party, LDP - Local Data Plane
      GDP - Global Data Plane, RED - Redundancy, UL - UL
Node 0/2/CPU0 (0x841)
Interface GigabitEthernet0/2/0/0, ifh 0x080000c0 (up, 9228)
  Interface flags:          0x000000000110059f (ROOT_IS_HW|IFCONNECTOR
                            |IFINDEX|SUP_NAMED_SUB|BROADCAST|CONFIG|HW|VIS
                            |DATA|CONTROL)
  Encapsulation:            ether
  Interface type:           IFT_GETHERNET
  Control parent:           None
  Data parent:              None
  Views:                    GDP|LDP|L3P|OWN
  Protocol        Caps (state, mtu)
  None            spio (up, 9228)
  None            sat_info (up, 9228)
  None            ether (down, 9228)
  link_jump_target link_jump_target (down, 9214)
  ether_sock      ether_sock (down, 9214)
debug is attached
Thanks one more time
The discovery packets are being generated, need to verify if they are leaving out the interface. They are sent 1/sec, only real way to verify is with show interface <icl>.
I would recommend opening up a TAC SR, I have seen this once or twice before and it takes a bit more digging. As an aside I have used The gig SFPs in my lab since 5.1.1 so I know they work.
Sam
anyway thanks for your help. I was trying to open a SR :)
Kind regards
