ASR9001 - IOS XR upgrade to 5.3.4 - SFP+ failing to function, FPGA version incorrect
i123
After upgrading to 5.3.4, FPA included, interfaces SFP+0 - 3 stopped functioning.  I noticed that fpga version was not right.
show hw-module fpd location 0/0$
Fri Dec 30 22:04:22.315 UTC
Existing Field Programmable Devices
HW Current SW Upg/
Location Card Type Version Type Subtype Inst Version Dng?
0/0/CPU0 ASR9001-LC 1.0 lc cbc 0 23.114 No
lc fpga2 0 255.255 No
lc fpga4 0 255.255 No
lc rommon 0 2.04 No
NOTES:
1. + One or more FPD is running up-rev FPGA version. Downgrade is "OPTIONAL" in this case.
It can be downgraded using the "admin> upgrade hw-module fpd <fpd> force location <loc>" CLI.
I then issued a forced downgrade on fpga4 and fpga2 to attempt to restore SFP+0/3 interfaces.
LC/0/0/CPU0:Dec 30 22:11:51.534 : lc_fpd_upgrade[256]: %PLATFORM-UPGRADE_FPD-6-START : Starting to downgrade fpga4 subtype image from 255.255 to 2.10 for on this card on location 0/0/CPU0
LC/0/0/CPU0:Dec 30 22:11:51.544 : fpd_fpga_agent[195]: %PLATFORM-FPD-6-INFO : fpd-info: Start Upgrade..., instance 0
LC/0/0/CPU0:Dec 30 22:11:51.718 : fpd_fpga_agent[195]: %PLATFORM-FPD-6-INFO : fpd-info: unzipping of fpd image will be done in : 0 harddisk:
LC/0/0/CPU0:Dec 30 22:11:53.436 : fpd_fpga_agent[195]: %PLATFORM-FPD-6-INFO : fpd-info: Programming fpd instance 0...with file /net/node0_RSP0_CPU0/harddisk:/fpd/whiplash.fpg.gz 0
RP/0/RSP0/CPU0:Dec 30 22:12:46.542 : upgrade_fpd_cli[65787]: %PLATFORM-UPGRADE_FPD-6-STATUS : FPD upgrade in progress. Max timeout remaining 89 min.
LC/0/0/CPU0:Dec 30 22:13:35.916 : lc_fpd_upgrade[256]: %PLATFORM-UPGRADE_FPD-6-PASSED : Successfully downgrade fpga4 subtype image for on this card on location 0/0/CPU0
RP/0/RSP0/CPU0:Dec 30 22:13:35.923 : upgrade_fpd_cli[65787]: %PLATFORM-UPGRADE_FPD-6-STATUS_LOC : Upgrade is going on: FPD upgrade completed for location node0_0_CPU0
RP/0/RSP0/CPU0:Dec 30 22:13:38.554 : upgrade_fpd_cli[65787]: %PLATFORM-UPGRADE_FPD-6-STATUS : FPD upgrade completed.
RP/0/RSP0/CPU0:Dec 30 22:16:50.782 : shelfmgr[398]: %PLATFORM-SHELFMGR-6-USER_RESET : Node 0/0/CPU0 is reset due to user reload request
However, it didn't take.
admin show hw-module fpd location all
Fri Dec 30 22:33:24.619 UTC
HW Current SW Upg/
0/RSP0/CPU0 ASR9001-RP 1.0 lc fpga2 0 1.15 No
lc cbc 0 22.114 No
lc rommon 0 2.04 No
0/FT0/SP ASR-9001-FAN 1.0 ft cbc 7 24.115 No
lc rommon 0 2.04 No
NOTES:
Attached is the full log of the downgrade and reload of 0/0/CPU0
Thanks in advance!
Aleksandar Vidakovic
version 255.255 is reported when the OS can't read the info from HW. In your case the real issue is this one:
RP/0/RSP0/CPU0:Dec 30 22:21:53.354 : FABMGR[220]: %PLATFORM-FABMGR-2-FABRIC_INTERNAL_FAULT : 0/0/CPU0 (slot 2) encountered fatal fabric fault.Interfaces are going to be shutdown.
It would be the best if you would open a TAC SR to analyse this further. It may be a HW fault.
regards,
/Aleksandar
regards,
/Aleksandar
It appears to be a HW fault. I forced a downgrade for kicks, no luck.  I do not have support on this chassis.  Are there any repair options/recommendations?  I'm aware that 0/0/CPU0 is not field replaceable, but is it replaceable at all?  EP(MPA) cards fail function as well.
RP and LC components of asr9001 are inseparable from the chassis. Only the MPAs, power supply and fan are field replaceable.
