ASR9001 LISP documentation
klaus.kruse
Hello Fellas,
We have a pretty decent #ASR9001 running IOS XR 6.6.2 and struggle to implement Locator Identity Separation Protocol (LISP) services on this. So far, we've just found configuration guides and command references for other platforms or older (4.x) releases, but some commands have changed.
Can anyone point me to the correct documents? I've searched a lot on specifications overview (https://www.cisco.com/c/en/us/support/routers/asr-9001-router/model.html), but this time without luck.
Kind regards
Klaus Kruse
xthuijs
hi klaus,
you know I want to say that we started to deprecate LISP somewhere around 63 or alerting on it that is and that the last sw release for LISP is 642.
it may not have been fully removed from the code, but probably its best to use 642 EMR for this test.
the regular documentation should apply there.
cheers!
xander
xthuijs
hi klaus,
cheers!
xander
Thanks, that's what I assumed already.
Interesting, Xander, thanks for sharing. ;)
Elvin
