ASR9001 Port Numbering
dfranjoso
Does anybody knows the port numbering used on the Cisco ASR9001 for the
Left MPA
Right MPA
Built-in 10GbE interfaces
I'm assuming that with NV technology in place, the chassi number would be 0 for the primary DSC and 1 for the secondary DSC.
Thanks!
David
Alexei Kiritchenko
Hello David,
Left slot is named Bay 0, so, no surprise, that would be 0
Right slot is named Bay 1, so 1.
The build in port are treated as in slot 2.
Bay 0 - 0/0/0/x
Bay 1 - 0/0/1/x
The buildin ports:
      TenGigE0/0/2/0
      TenGigE0/0/2/1
      TenGigE0/0/2/2
      TenGigE0/0/2/3
Yes, with the cluster we get 1 for the second chassis:
RP/0/RSP0/CPU0:ios#show platform
Node            Type                      State            Config State
0/RSP0/CPU0     ASR9001-RP(Active)        IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        ASR9001-LC                IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0/0/1           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
1/RSP0/CPU0     ASR9001-RP(Active)        IOS XR RUN       PWR,NSHUT,MON
1/0/CPU0        ASR9001-LC                IOS XR RUN       PWR,NSHUT,MON
1/0/0           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
1/0/1           A9K-MPA-2X10GE            OK               PWR,NSHUT,MON
/A
Once again thanks Alexei.
Of course the HW documentation guide has several bugs (but you are always here to help!)
Remember that Cisco ASR 9001 Router rack and subslot values are always 0 (zero).
which contradicts
The line card slot is numbered 0 with three subslots. The subslots on the line card are numbered 0, 1, and 2. 0 and 1 are reserved for EP ports and 2 is for native ports on the line card. Even if the line card contains only one port, you must use the rack/slot/instance/port notation.
I'll stick to this last paragraph, as you confirm.
PS: I did ask for 2 ASR9001 from Cisco demo depot, but they are being built and delivered only in a couple of weeks !!! Can you lend my yours ?
he he, poor TAC has only 1 now, so I may assume you'd get yours faster them we
/A
