ASR9006 span port monitor-session subinterface
   In an ASR9006 platform with A9K-24X10GE-TR modules and image 6.4.2 I am unable to have a working SPAN port from a source subinterface. I'm using this configuration:
monitor-session capture ethernet
  destination interface TenGigE0/2/0/14
...snip...
interface TenGigE0/1/0/22.8
 description *** END USER C1248 ***
service-policy type control subscriber PPP_PM
pppoe enable bba-group CUSTOMERS
encapsulation dot1q 1605 second-dot1q 1804
...snip...
description --- to Wireshark server ---
l2transport
The SPAN configuration appear to be operational:
RP/0/RSP0/CPU0#sh monitor-session status detail
Monitor-session capture
Destination interface TenGigE0/2/0/14
Source Interfaces
TenGigE0/1/0/22.8
Direction: Both
Port level: False
ACL match: Disabled
Portion: Full packet
Interval: Mirror all packets
Status: Operational
The problem is that there are no packet captured:
RP/0/RSP0/CPU0#show monitor-session counters
Thu Jun 10 15:43:53.928 CET
TenGigE0/1/0/22.8
Rx replicated: 0 packets, 0 octets
Tx replicated: 0 packets, 0 octets
Non-replicated: 0 packets, 0 octets
In the source interface there is traffic but in the SPAN port not.
RP/0/RSP0/CPU0#sh int TenGigE 0/1/0/22.8 | include rate
Thu Jun 10 15:44:25.924 CET
30 second input rate 537000 bits/sec, 201 packets/sec
30 second output rate 2982000 bits/sec, 771 packets/sec
RP/0/RSP0/CPU0#sh int TenGigE0/2/0/14
Thu Jun 10 15:46:44.689 CET
TenGigE0/2/0/14 is up, line protocol is up
Interface state transitions: 19
Hardware is TenGigE, address is 70e4.2222.5d3e (bia 70e4.2222.5d3e)
Layer 1 Transport Mode is LAN
Description: *** Porta XN2 ***
Layer 2 Transport Mode
MTU 1514 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
reliability 5/255, txload 0/255, rxload 0/255
Encapsulation ARPA,
Full-duplex, 10000Mb/s, SR, link type is force-up
output flow control is off, input flow control is off
Carrier delay (up) is 10 msec
loopback not set,
Last link flapped 2d19h
Last input 00:00:00, output 02:51:16
Last clearing of "show interface" counters 00:00:07
5 minute input rate 0 bits/sec, 1 packets/sec
3 packets input, 180 bytes, 3 total input drops
0 drops for unrecognized upper-level protocol
Received 0 broadcast packets, 3 multicast packets
0 runts, 0 giants, 0 throttles, 0 parity
765 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 total output drops
Output 0 broadcast packets, 0 multicast packets
0 output errors, 0 underruns, 0 applique, 0 resets
0 carrier transitions
Do you have any idea to help me?
Thankyou
Gianrico Fichera
smilstea
You need to put a tag on the outgoing interface towards the capture device when using a sub-int with a VLAN tag, otherwise nothing is captured.
https://community.cisco.com/t5/service-providers-documents/asr9000-xr-how-to-use-port-spanning-or-port-mirroring/ta-p/3108031
Scroll down to "
R-SPAN configuration:"
Sam
 Hello, thank you for your answer.
I changed the configuration trying to follow the examples you kindly showed me.
   transceiver permit pid all
interface TenGigE0/2/0/14.1 l2transport
  description *** R-SPAN port ***
description *** CUSTOMER SIDE INTERFACE ***
  pppoe enable bba-group TEKNONET
  load-interval 30
Now I have this status:
RP/0/RSP0/CPU0:core.as202975.net#show monitor-session status detail
Mon Jun 14 10:41:23.395 CET
Destination interface TenGigE0/2/0/14.1
Source Interfaces
TenGigE0/1/0/22.8
Direction: Both
Port level: False
ACL match: Disabled
Status: Operational
It seems that nothing changed:
RP/0/RSP0/CPU0:core.as202975.net#sh int tenGigE 0/1/0/22.8
Mon Jun 14 10:46:40.166 CET
TenGigE0/1/0/22.8 is up, line protocol is up
Interface state transitions: 11
Hardware is VLAN sub-interface(s), address is 046c.9d59.e8ce
Description: ***CUSTOMER SIDE INTERFACE ***
Internet address is Unknown
MTU 1522 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
reliability 255/255, txload 0/255, rxload 0/255
Encapsulation 802.1Q Virtual LAN, VLAN Id 1605, 2nd VLAN Id 1804,
loopback not set,
Last link flapped 3d19h
Last input 00:00:01, output 00:00:01
Last clearing of "show interface" counters 6d00h
30 second input rate 51000 bits/sec, 32 packets/sec
30 second output rate 110000 bits/sec, 28 packets/sec
135709184 packets input, 77463405249 bytes, 1635 total input drops
Received 0 broadcast packets, 0 multicast packets
135278267 packets output, 93171992952 bytes, 0 total output drops
RP/0/RSP0/CPU0:core.as202975.net#sh int TenGigE0/2/0/14.1
Mon Jun 14 10:46:59.269 CET
TenGigE0/2/0/14.1 is up, line protocol is up
Hardware is VLAN sub-interface(s), address is 70e4.2222.5d3e
reliability Unknown, txload Unknown, rxload Unknown
Outer Match: Dot1Q VLAN 1605
Inner Match: Dot1Q VLAN 1804
Ethertype Any, MAC Match src any, dest any
loopback not set,
Last link flapped 00:16:26
Last input never, output never
0 packets input, 0 bytes
0 input drops, 0 queue drops, 0 input errors
0 output drops, 0 queue drops, 0 output errors
I don't understand the reason but in any case even now I have no traffic in the R-SPAN port.
  load-interval 30
Source Interfaces
TenGigE0/1/0/22.8
Direction: Both
Port level: False
ACL match: Disabled
Status: Operational
loopback not set,
loopback not set,
Ok so I think I know the issue, since this is BNG we need to configure SPAN via dynamic template or through CoA.
dynamic-template type <type> <name>
 monitor-session <name> [ direction {rx-only|tx-only} ]
  acl
  mirror first <bytes>
Template can be applied to existing subscribers via
new “CoA” CLI command
test radius coa activate service <name> acct-ses-id <id>
Sam
