ASR9006 upgrade IOS XR fail
nicolay1974
After upgrade ASR9006 from 4.2.0 to 4.3.2 the line card do not boot up properly.
I tryed to upgrade FPD on line card, but had not success. What i can do now?
RP/0/RSP0/CPU0:LAB-9k-440#sh plat
Tue Sep 24 17:53:20.083 UTC
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-40GE-L                BRINGDOWN        PWR,NSHUT,MON
0/2/CPU0        A9K-MOD80-TR              IN-RESET         PWR,NSHUT,MON
RP/0/RSP0/CPU0:LAB-9k-440(admin)#upgrade hw-module fpd rommon location 0/0/CPU0
Tue Sep 24 17:57:56.274 UTC
***** UPGRADE WARNING MESSAGE: *****
  *  This upgrade operation has a maximum timout of 160 minutes.  *
  *  If you are executing the cmd for one specific location and  *
  *  card in that location reloads or goes down for some reason  *
  *  you can press CTRL-C to get back the RP's prompt.           *
  *  If you are executing the cmd for _all_ locations and a node *
  *  reloads or is down please allow other nodes to finish the   *
  *  upgrade process before pressing CTRL-C.                     *
% RELOAD REMINDER:
  - The upgrade operation of the target module will not interrupt its normal
    operation. However, for the changes to take effect, the target module
    will need to be manually reloaded after the upgrade operation. This can
    be accomplished with the use of "hw-module <target> reload" command.
  - If automatic reload operation is desired after the upgrade, please use
    the "reload" option at the end of the upgrade command.
  - The output of "show hw-module fpd location" command will not display
    correct version information after the upgrade if the target module is
    not reloaded.
NOTE: Chassis CLI will not be accessible while upgrade is in progress.
Continue? [confirm]
22 Replies 22
yeap i want to upgread from the 5.1.3 to 5.3.3 but my files are in the harddisk 0/RSP1/CPU0 but i dont want to do switchover from the RSP0 to RSP1 u know  answer for this ??
regards
Easiest way is to install add from FTP/TFTP server.
I tried to install from TAR once and never again. It takes just too long and you will also get packages that you don't need.
It's better to unzip the tar file and install add individual packages.
Something like this.
admin ---> install add ftp://10.100.13.133/asr9k-mini-px.pie-4.3.4 ftp://10.100.13.133/asr9k-doc-px.pie-4.3.4 ftp://10.100.13.133/asr9k-fpd-px.pie-4.3.4
Check what packages are active with admin show install active summary and add the same packages. You should also deactivate packages that are not in use.
e.q. asr9k-mcast-px-5.1.3 if you do not use multicast.
You should also check this doc.
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/ASR9k_Upgrade_Downgrade_Procedure_IOSXR_Rel_512.pdf
i know the process from FTP/TFTP but i want to know if is possible install from the harddisk RSP1 from the RSP0 active. why? My TAR file its in harddisk of RSP1 but i dont know how to call this file in the command install add
regards
Just sent you the steps on your post. Smail Milak is correct, its a little slow on 5.1.3, from 5.3.3 onwards with RSP440 and new gen RSPs, the install add of a TAR should take no more then a few mins, we improved the write speed by about 500%. You need to be on 533 though.
Eddie.
Well it looks like that you can not specify the location (RSP1) from where you want to install add the tar file.
Please see my previous post:
https://supportforums.cisco.com/discussion/12961376/upgrade-asr9k-533
Eddie.
The issue with the speed used to be that the file was transferred twice when doing an install add from a remote filesystem. Don't know if this is still the case with more recent releases.
The way I have always done it is to make my own tar file containing only the PIEs that I want then sftp it to harddisk:/ (only one transfer) then do the install add from the local filesystem.
If you transfer in-band rather than via MgmtEther you can also greatly speed it up by increasing the LPTS policer limits.
Hi Nicolay, I'm facing the same issues, in the show logs I saw similar messages, from your post I understood is requiered a SW Upgrade in the nodes, that's right?
RP/0/RSP1/CPU0:Feb  2 08:45:34.783 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG SReset (0x06000000)
RP/0/RSP1/CPU0:Feb  2 08:45:50.789 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG HReset (0x07000000)
RP/0/RSP1/CPU0:Feb  2 08:45:51.797 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG Power Cycle (0x08000000)
RP/0/RSP1/CPU0:Feb  2 09:15:54.870 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG SReset (0x06000000)
RP/0/RSP1/CPU0:Feb  2 09:16:10.875 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG HReset (0x07000000)
RP/0/RSP1/CPU0:Feb  2 09:16:11.871 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG Power Cycle (0x08000000)
RP/0/RSP1/CPU0:Feb  2 09:46:14.939 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG SReset (0x06000000)
RP/0/RSP1/CPU0:Feb  2 09:46:30.993 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG HReset (0x07000000)
RP/0/RSP1/CPU0:Feb  2 09:46:31.989 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG Power Cycle (0x08000000)
RP/0/RSP1/CPU0:Feb  2 10:16:35.075 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG SReset (0x06000000)
RP/0/RSP1/CPU0:Feb  2 10:16:51.056 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG HReset (0x07000000)
RP/0/RSP1/CPU0:Feb  2 10:16:52.064 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG Power Cycle (0x08000000)
RP/0/RSP1/CPU0:Feb  2 10:46:55.135 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG SReset (0x06000000)
RP/0/RSP1/CPU0:Feb  2 10:47:11.141 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG HReset (0x07000000)
RP/0/RSP1/CPU0:Feb  2 10:47:12.161 : canb-server[155]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/RSP0/CPU0 , WDOG Power Cycle (0x08000000)
RP/0/RSP1/CPU0:Feb  2 11:09:00.462 : shelfmgr[404]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 UNKNOWN state:UNPOWERED
RP/0/RSP1/CPU0:Feb  2 11:09:03.768 : shelfmgr[404]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-8X10GE state:POWER UP
LC/0/0/CPU0:Feb  2 11:09:04.590 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA in bay 0 type A9K-MPA-8x10GE Initing
RP/0/RSP1/CPU0:Feb  2 11:09:08.412 : shelfmgr[404]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 UNKNOWN state:UNPOWERED
RP/0/RSP1/CPU0:Feb  2 11:09:10.632 : shelfmgr[404]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-8X10GE state:INITIALIZED
RP/0/RSP1/CPU0:Feb  2 11:09:11.701 : shelfmgr[404]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 A9K-MPA-8X10GE state:POWER UP
RP/0/RSP1/CPU0:Feb  2 11:09:11.836 : invmgr[258]: %PLATFORM-INV-6-IF_OIRIN : xFP OIR: 0/0/0 port_num: 0 is inserted, state: 1
LC/0/0/CPU0:Feb  2 11:09:12.226 : lda_server[65]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : fpga8 instance 0 is down-rev (V1.05), upgrade to (V1.07). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/0/CPU0:Feb  2 11:09:12.504 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA in bay 1 type A9K-MPA-8x10GE Initing
RP/0/RSP1/CPU0:Feb  2 11:09:13.432 : invmgr[258]: %PLATFORM-INV-6-IF_OIRIN : xFP OIR: 0/0/0 port_num: 1 is inserted, state: 1
RP/0/RSP1/CPU0:Feb  2 11:09:15.025 : invmgr[258]: %PLATFORM-INV-6-IF_OIRIN : xFP OIR: 0/0/0 port_num: 2 is inserted, state: 1
RP/0/RSP1/CPU0:Feb  2 11:09:16.285 : shelfmgr[404]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-8X10GE state:OK
RP/0/RSP1/CPU0:Feb  2 11:09:16.623 : invmgr[258]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/0, state: OK
RP/0/RSP1/CPU0:Feb  2 11:09:16.627 : invmgr[258]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/0/0 Sn: FOC2123NHSQ inserted
RP/0/RSP1/CPU0:Feb  2 11:09:16.632 : invmgr[258]: %PLATFORM-INV-6-IF_OIRIN : xFP OIR: 0/0/0 port_num: 3 is inserted, state: 1
LC/0/0/CPU0:Feb  2 11:09:16.877 : ifmgr[209]: %PKT_INFRA-LINK-5-CHANGED : Interface TenGigE0/0/0/0, changed state to
