ASR9901
Georgios Bekos
Can someone share maximum sub interfaces supported on ASR9901 & ASR9910.
Thanks in advance.
tkarnani
the scale is per line card.
you can check the following output for example to see
show ethernet hardware capability location 0/0/CPU0
So in my case of asr9901 i can use 131072 vlan sub interfaces ?
Does it match with  a maximum IFT_VLAN_SUBIF from the "show interfaces summary" command?
Card Type: ASR9901-LC
Card Name: ASR 9901, Line Card
LC Interface Scale limits:
Max L3 Interfaces : 32768
Max L3 Bundle Interfaces : 32768
Max L2 Interfaces : 131072
Max L2 Bundle Interfaces : 131072
Max Total Interfaces : 131072
NP Interface Scale limits:
Max L2 Interfaces : 65536
Max L2 Bundle Interfaces : 65536
Max Total Interfaces : 65536
Virtual Trunk Scale Limits:
Max L3 Bundles Subs per trunk : 4096
Max L2 Bundles Subs per trunk : 4096
Max Total Bundle Subs per trunk : 4096
Max L3 PWHE Subs per trunk : 4096
Max L2 PWHE Subs per trunk : 4096
Max Total PWHE Subs per trunk : 4096
Max L3 Satellite Subs per trunk : 4096
Max L2 Satellite Subs per trunk : 4096
Max Total Satellite Subs per trunk : 4096
Best regards,
