ASR9K BNG Bundle-Ether interface policers duplication for pQoS services
peter.ivanov
Good Day!
We terminate PPPoE sessions on A9K-4T16GE-SE line card. We apply pQoS service for each PPPoE session.
RP/0/RSP0/CPU0:mskl05#show policy-map applied interface TenGigE0/2/0/16.4001.pppoe4228
Wed Jul 25 08:57:13.220 UTC
Input policy-map applied to TenGigE0/2/0/16.4001.pppoe4228:
  policy-map __sub_ffffffbf5631ffffffaa
   class cmSrvRetail_LocalAccess_In
    police rate 100000 kbps
   class cmSrvRetail_InternetAccess_Night
    police rate 45000 kbps
   class cmSrvRetail_InternetAccess_Day
    police rate 15000 kbps
   class class-default
Output policy-map applied to TenGigE0/2/0/16.4001.pppoe4228:
  policy-map __sub_21727fffffff94
   class cmSrvRetail_LocalAccess_Out
   class class-default
This line card support 32K sessions.
RP/0/RSP0/CPU0:mskl05#show subscriber session all summary
Wed Jul 25 08:52:45.741 UTC
Session Summary Information for all nodes
                Type            PPPoE           IPSub           IPSub
                                                (DHCP)          (PKT)
Session Counts by State:
        initializing            0               0               0
          connecting            0               0               0
           connected            141             0               0
           activated            32768           0               0
                idle            0               0               0
       disconnecting            0               0               0
                 end            0               0               0
              Total:            32909           0               0
Session Counts by Address-Family/LAC:
         in progress            141             0               0
           ipv4-only            32768           0               0
           ipv6-only            0               0               0
     dual-partial-up            0               0               0
             dual-up            0               0               0
                 lac            0               0               0
              Total:            32909           0               0
Within each pQoS service is used 3 ingress and 3 egress policers. That is why the total policers is 196608.
RP/0/RSP0/CPU0:mskl05#show qoshal resource summary location 0/2/CPU0
Wed Jul 25 08:58:22.676 UTC
TY Options argc:5
nphal_show_chk -p 2113 resource summary
Done
-1
Counters: X(Y/Z): X -> Resources Allocated in HW
                  Y -> Resource Allocated in SW
                  Z -> Refcount of each resource
                  Sanity Check: X==Y && Z >= X
        :X (Y):   X -> Resource Allocated in HW
Client - 0, General - Not any Specific Client
 SW and RefCount for Entities are accounted in Client 0(general)
 Only HW count for Entities is per client
NP 0
 CLIENT : None-General
   Policy Instances: Ingress 0 Egress 0  Total: 0
    Entities: (L4 level: Queues)
     Level        Chunk 0           Chunk 1           Chunk 2           Chunk 3
     L4         0(    0/    0)    0(    0/    0)    0(    0/    0)    0(    0/    0)
     L3(8Q)     0(    0/    0)    0(    0/    0)    0(    0/    0)    0(    0/    0)
     L2         0(    0/    0)    0(    0/    0)    0(    0/    0)    0(    0/    0)
     L1         0(    0/    0)    0(    0/    0)    0(    0/    0)    0(    0/    0)
        Policers: Internal 0(0) Regular 0(0)  Parent 0(0)  Child 0(0)  Total 0(0)
 CLIENT : Pre-IFIB
   Policy Instances: Ingress 6 Egress 0  Total: 6
        Policers: Internal 0(0) Regular 280(280)  Parent 0(0)  Child 0(0)  Total 280(280)
 CLIENT : QoS-EA
   Policy Instances: Ingress 32768 Egress 32768  Total: 65536
     L3(16Q)    0(    0/    0)    0(    0/    0)    0(    0/    0)    0(    0/    0)
        Policers: Internal 2046(2046) Regular 194562(194562)  Parent 0(0)  Child 0(0)  Total 196608(196608)
The problem is noticed when we use Bundle-Ether interface for sessions termination.  The whole set of policers are applied for each physical port inside Bundle-Ether interface. It means that the quantity of sessions is reduced several times depending on the number of ports. For example, Bundle-Ether interface which consist of 4 ports the maximum sessions is 8K (4 times less).
Wed Jul 25 14:53:16.414 UTC
                                                (DHCP)          (PKT)
        initializing            0               0               0
          connecting            0               0               0
           connected            200             0               0
           activated            8192            0               0
                idle            0               0               0
       disconnecting            0               0               0
                 end            0               0               0
              Total:            8392            0               0
         in progress            200             0               0
           ipv4-only            8192            0               0
           ipv6-only            0               0               0
             dual-up            0               0               0
                 lac            0               0               0
              Total:            8392            0               0
Applied pQoS service for PPPoE session on Bundle-Ether interface.
RP/0/RSP0/CPU0:mskl05#show policy-map applied interface Bundle-Ether7.4001.pppoe8
Wed Jul 25 14:58:47.160 UTC
Input policy-map applied to Bundle-Ether7.4001.pppoe8:
   class class-default
Output policy-map applied to Bundle-Ether7.4001.pppoe8:
   class class-default
For 8K sessions total policers is 196608 (4 times more).
Wed Jul 25 15:00:00.962 UTC
TY Options argc:5
Done
-1
NP 0
 CLIENT : Pre-IFIB
 CLIENT : QoS-EA
   Policy Instances: Ingress 32768 Egress 32769  Total: 65537
        Policers: Internal 2043(2043) Regular 194568(194568)  Parent 0(0)  Child 0(0)  Total 196611(196611)
Is it possible to change this behavior for Bundle-Ether interface? We would like to have 32K sessions for Bundle-Ether interface. And it is critical moment because sessions on Bundle-Ether interface is RP sessions without any functional restriction. As we know for LC sessions there are some restrictions. Also Bundle-Ether interface provide load-balance and redundancy in compare with physical ports.
ASR9K Software specification
RP/0/RSP0/CPU0:mskl05#show install
Thu Jul 26 12:26:23.921 UTC
Secure Domain Router: Owner
  Node 0/RSP0/CPU0 [RP] [SDR: Owner]
    Boot Device: disk0:
    Boot Image: /disk0/asr9k-os-mbi-6.1.4/0x100305/mbiasr9k-rsp3.vm
    Active Packages:
      disk0:asr9k-services-infra-6.1.4
      disk0:asr9k-video-px-6.1.4
      disk0:asr9k-services-px-6.1.4
      disk0:asr9k-optic-px-6.1.4
      disk0:asr9k-mpls-px-6.1.4
      disk0:asr9k-mini-px-6.1.4
      disk0:asr9k-mgbl-px-6.1.4
      disk0:asr9k-mcast-px-6.1.4
      disk0:asr9k-li-px-6.1.4
      disk0:asr9k-k9sec-px-6.1.4
      disk0:asr9k-fpd-px-6.1.4
      disk0:asr9k-doc-px-6.1.4
      disk0:asr9k-bng-px-6.1.4
  Node 0/2/CPU0 [LC] [SDR: Owner]
    Boot Device: mem:
    Boot Image: /disk0/asr9k-os-mbi-6.1.4/lc/mbiasr9k-lc.vm
    Active Packages:
7 Replies 7
Aleksandar Vidakovic
hi Peter,
this is per design. On distributed platforms all bundle ethernet control structures are replicated over all bundle members. If you are not applying any queueing action on subscriber interfaces (which seems to be the case based on the outputs you have shared), you can go beyond 32k subscribers per NP, all the way until you run out of uidbs (microcode interface descriptors). To see how many uidbs are in use and what's the max available use either "sh controllers np struct EGR-UIDB summary location <location>" or "sh uidb index summary location <location>". This is not something we recommend, mostly because once you approach the max uidb scale, the dynamics of uidb allocation/release (as subscriber sessions are flapping) may prevent you from reaching the full limit. So you can exceed 32k, but don't go all the way. :) The scale per LC remains 64k subscribers, you can't go beyond that.
If you need high scale with a lot of throughput (i.e. more than two bundle members), it would be better to consider a LC with more NPs or go for upgrade to 6.3.3 eXR (requires Tomahawk), where the supported scale is higher.
I'd also suggest upgrading to 6.2.3 + latest Service Pack or SMUs. If not already doing that, use CSM Server to optimise the list for your deployment and manage the actual installation.
hope this helps,
Aleksandar
Aleksandar, thanks a lot for your answer!
But in our case the problem not in uidbs.  For the maximum 8K sessions on Bundle-Ether interface (4x10G) we have 8000 uidbs with max available 65536.
RP/0/RSP0/CPU0:mskl05#show controllers np struct EGR-UIDB summary location 0/2/CPU0
Thu Jul 26 16:00:53.858 UTC
                Node: 0/2/CPU0:
NP: 0  Struct 10: EGR_UIDB
Struct is a PHYSICAL entity
Reserved Entries: 0, Used Entries: 8056, Max Entries: 65536
There is any way for particular bundle Ethernet interface NOT replicate over all bundle members control structures? In our case it is policers.
Can you attach the full output of "show bundle <bundle-int>", "sh controllers np ports all ...", "sh qoshal resource summary ..." and "sh qos interface <subs-interface> output member <member> ..."? If you're stuck at 8k, it means there's some traffic manager resource in use. With queuing actions on subscriber interfaces you are limited to 32k subscribers, with max 8k per TM chunk.
Replicating all structures over all bundle members is at the core of BE implementation. Many of the features wouldn't work as expected should we try to change that. Let's find an alternative way to unleash the full potential of the asr9k BNG solution.
/Aleksandar
Aleksandar, Good day!
Sending output of the commands.
RP/0/RSP0/CPU0:mskl05#show bundle bundle-ether 7
Fri Jul 27 07:24:27.899 UTC
Bundle-Ether7
  Status:                                    Up
  Local links <active/standby/configured>:   4 / 0 / 4
  Local bandwidth <effective/available>:     40000000 (40000000) kbps
  MAC address (source):                      d867.d959.deb7 (Chassis pool)
  Inter-chassis link:                        No
  Minimum active links / bandwidth:          1 / 1 kbps
  Maximum active links:                      64
  Wait while timer:                          2000 ms
  Load balancing:
    Link order signaling:                    Not configured
    Hash type:                               Default
    Locality threshold:                      None
  LACP:                                      Operational
    Flap suppression timer:                  Off
    Cisco extensions:                        Disabled
    Non-revertive:                           Disabled
  mLACP:                                     Not configured
  IPv4 BFD:                                  Not configured
  IPv6 BFD:                                  Not configured
  Port                  Device           State        Port ID         B/W, kbps
  Te0/2/0/16            Local            Active       0x8000, 0x000a    10000000
      Link is Active
  Te0/2/0/17            Local            Active       0x8000, 0x0009    10000000
      Link is Active
  Te0/2/0/18            Local            Active       0x8000, 0x0008    10000000
      Link is Active
  Te0/2/0/19            Local            Active       0x8000, 0x0007    10000000
      Link is Active
RP/0/RSP0/CPU0:mskl05#show controllers np ports all location 0/2/CPU0
Fri Jul 27 07:27:47.792 UTC
                Node: 0/2/CPU0:
NP Bridge Fia                       Ports
0  --     0   GigabitEthernet0/2/0/0 - GigabitEthernet0/2/0/15, TenGigE0/2/0/16 - TenGigE0/2/0/19
Fri Jul 27 08:09:24.125 UTC
TY Options argc:5
Done
-1
NP 0
 CLIENT : Pre-IFIB
 CLIENT : QoS-EA
 CLIENT : L2 Fib
   Policy Instances: Ingress 2 Egress 0  Total: 2
        Policers: Internal 4(4) Regular 0(0)  Parent 0(0)  Child 0(0)  Total 4(4)
 CLIENT : Interflex
 CLIENT : Span
 CLIENT : Platform Manager
   Policy Instances: Ingress 20 Egress 20  Total: 40
     L4        40(   40/   40)   40(   40/   40)   40(   40/   40)   40(   40/   40)
     L3(8Q)    10(   10/   10)   10(   10/   10)   10(   10/   10)   10(   10/   10)
     L2        10(   10/   10)   10(   10/   10)   10(   10/   10)   10(   10/   10)
     L1        40(   40/   40)    0(    0/    0)    0(    0/    0)    0(    0/    0)
 CLIENT : IRB
 CLIENT : Internal
   Policy Instances: Ingress 5 Egress 0  Total: 5
     L4        16(   16/   16)    0(    0/    0)    0(    0/    0)    0(    0/    0)
     L3(8Q)     4(    4/    4)    0(    0/    0)    0(    0/    0)    0(    0/    0)
     L2         3(    3/    3)    0(    0/    0)    0(    0/    0)    0(    0/    0)
     L1         3(    3/    3)    0(    0/    0)    0(    0/    0)    0(    0/    0)
        Policers: Internal 1(1) Regular 0(0)  Parent 0(0)  Child 0(0)  Total 1(1)
 CLIENT : SVC
 CLIENT : Experimental 2
 CLIENT : SCOPP
 CLIENT : CLUSTER
 CLIENT : QoS-Virtual-IF
 CLIENT : SAT-EA
 CLIENT : MAX
 CLIENT : P
  SUMMARY per NP:
   Policy Instances: Ingress 32801 Egress 32789  Total: 65590
     L4        56(   56/   56)   40(   40/   40)   40(   40/   40)   40(   40/   40)
     L3(8Q)    14(   14/   14)   10(   10/   10)   10(   10/   10)   10(   10/   10)
     L2        13(   13/   13)   10(   10/   10)   10(   10/   10)   10(   10/   10)
     L1        43(   43/   43)    0(    0/    0)    0(    0/    0)    0(    0/    0)
   Groups:
     L4        14(   14/   14)   10(   10/   10)   10(   10/   10)   10(   10/   10)
     L3(8Q)    13(   13/   13)   10(   10/   10)   10(   10/   10)   10(   10/   10)
   Policers: Internal 2048(2048) Regular 194848(194848)  Parent 0(0) Child 0(0) Total 196896(196896)
   PROFILES:
      WFQ:
        L4  254( 254/    56)  254( 254/    40)  254( 254/    40)  254( 254/    40)
        L3  256( 256/    14)  256( 256/    10)  256( 256/    10)  256( 256/    10)
        L2  256( 256/    13)  256( 256/    10)  256( 256/    10)  256( 256/    10)
        L1   64(  64/    40)    0(   0/     0)    0(   0/     0)    0(   0/     0)
      SHAPE:
        L4    1(   1/     1)    0(   0/     0)    0(   0/     0)    0(   0/     0)
        L3    0(   0/     0)    0(   0/     0)    0(   0/     0)    0(   0/     0)
        L1    2(   2/    20)    0(   0/     0)    0(   0/     0)    0(   0/     0)
      WRED:
        L4   16(  16/     0)    0(   0/     0)    0(   0/     0)    0(   0/     0)
        L1    3(   3/    23)    0(   0/     0)    0(   0/     0)    0(   0/     0)
      POLICE:
         In HW (In Sw/ Ref count) :   66 (  66 / 196896)
RP/0/RSP0/CPU0:mskl05#show qos interface Bundle-Ether7.4003.pppoe7812 output member tenGigE 0/2/0/16
Fri Jul 27 08:12:02.206 UTC
Interface: TenGigE0_2_0_16 output
Bandwidth configured: 10000000 kbps Bandwidth programed: 10000000 kbps
ANCP user configured: 0 kbps ANCP programed in HW: 0 kbps
Port Shaper programed in HW: 0 kbps
Policy: __sub_21727fffffff94 Total number of classes: 4
Level: 0 Policy: __sub_21727fffffff94 Class: cmSrvRetail_LocalAccess_Out
QueueID: 386 (Port Default)
Policer Profile: 63 (Single)
Conform: 100000 kbps (100000 kbps) Burst: 1250000 bytes (0 Default)
Child Policer Conform: TX
Child Policer Exceed: DROP
Child Policer Violate: DROP
Level: 0 Policy: __sub_21727fffffff94 Class: cmSrvRetail_InternetAccess_Night
Policer Profile: 64 (Single)
Conform: 45000 kbps (45000 kbps) Burst: 562500 bytes (0 Default)
Level: 0 Policy: __sub_21727fffffff94 Class: cmSrvRetail_InternetAccess_Day
Policer Profile: 65 (Single)
Conform: 15000 kbps (15000 kbps) Burst: 187500 bytes (0 Default)
Level: 0 Policy: __sub_21727fffffff94 Class: class-default
RP/0/RSP0/CPU0:mskl05#show qos interface Bundle-Ether7.4003.pppoe7812 output member tenGigE 0/2/0/17
Fri Jul 27 08:13:34.039 UTC
Interface: TenGigE0_2_0_17 output
QueueID: 65826 (Port Default)
RP/0/RSP0/CPU0:mskl05#show qos interface Bundle-Ether7.4003.pppoe7812 output member tenGigE 0/2/0/18
Fri Jul 27 08:13:48.248 UTC
Interface: TenGigE0_2_0_18 output
QueueID: 131362 (Port Default)
RP/0/RSP0/CPU0:mskl05#show qos interface Bundle-Ether7.4003.pppoe7812 output member tenGigE 0/2/0/19
Fri Jul 27 08:13:58.279 UTC
Interface: TenGigE0_2_0_19 output
QueueID: 196898 (Port Default)
hi Peter,
the queueing resources are fine. All the queues in use are the port default queues.
The scale limit that you are approaching (but not reached yet!) is 256k policers per NP:
What kind of error is reported when you try to bring up more subscribers?
/Aleksandar
Hi, Aleksandar
I can't track errors that would clearly identify the cause of the problem. I have got only this output.
RP/0/RSP0/CPU0:Jul 30 08:22:24.736 : pppoe_ma[394]: Bundle-Ether7.4010: I dst d867.d959.deb7 src 5254.0066.0faa: len 38 0x11190000000a010100000120000205dc00000000000000000000000000000000000000000000
RP/0/RSP0/CPU0:Jul 30 08:22:24.736 : pppoe_ma[394]: [PADR-Recv]: Bundle-Ether7.4010 peer-mac 5254.0066.0faa
RP/0/RSP0/CPU0:Jul 30 08:22:24.736 : pppoe_ma[394]: [PADR-Recv]:    vlan-id-outer 4010 vlan-id-inner 102
RP/0/RSP0/CPU0:Jul 30 08:22:24.736 : pppoe_ma[394]: [PADR-Recv]:    Service-name:
RP/0/RSP0/CPU0:Jul 30 08:22:24.736 : pppoe_ma[394]: [PADR-Recv]:    Max-payload: 1500
RP/0/RSP0/CPU0:Jul 30 08:22:24.736 : pppoe_ma[394]: [PADR-Recv]:   DROPPED - session throttle or flow control
hi Peter,
apologies for the delay. BNG implementation on XR uses the concept of "pppoe in-flight-window". You can see the related stats using the "sh pppoe summary total". It may simply be that the CPS rate was too high for all the work that needs to be done to activate the required features on the subscriber interface.
/Aleksandar
