ASR9K Bridging & Routing Over Same EVPL/EPL Link
mohammar
Hey guys,
I've got an ASR9K that's connected to a Layer 2 circuit (VZ EPL/EVPL). I want to be able to run BGP as well as extend a few VLANs across the same Layer 2 link to the far-end. Is this possible over the same L2 link?
Any direction with configs would be greatly appreciated!
Thanks.
xthuijs
yup sure can!
either you can chose to desginate a new vlan for that session, or if you want to run it inband you can do that also with a bvi:
int g0/0/0/0.100
encap dot1q 100
ipv4 add....
router bgp
neig... etc
or if you have an existing circuit, say g 0/0/0/0 l2trans
then confgure
int bvi 999
ip add...
l2vpn
bridge-group X
bridge-domain Y
int g 0/0/0/0
routed interface bvi999
xander
