ASR9k DWDM 10G SFP+ tunable 50Ghz interoperability with 100Ghz fixed optics
I have two routers connected via a point to point layer1 dwdm fibre link via fixed 10G DWDM optics which are based on ITU 100GHz (eg DWDM-SFP10G-61.41). This works fine with no issues.
Im upgrading one router to asr9k and got DWDM-SFP10G-C for the 9k. I configured it to the wavelength required but I see that the tunables are based on 50Ghz not 100Ghz like the fixed.
ASR9K#sh run controller dwdm 0/8/0/23
Tue Jul 19 13:08:20.750 CET
controller dwdm0/8/0/23
wavelength 50GHz-Grid update 1535822
ASR9K#sh controllers dwdm 0/8/0/23 opti$
Tue Jul 19 13:07:41.660 CET
Optics Status
Optics Type: 10GBASE-TUNABLE
Wavelength Info: C-Band, MSA ITU Channel=19, Frequency=195.20THz, Wavelength=1535.822nm
Wavelength Owner: Configuration, ITU Channel: GMPLS Signaled=None, Configured=19, Hardware Default=84
TX Power = 0.00 dBm
RX Power = -40.00 dBm
Question: Is it a correct and supported configuration for a link between two routers having a fixed 100Ghz dwdm optic on one side and a tunable 50Ghz dwdm on the other end of the link. Note dwdm filters in the field are also based on 100Ghz
thanks
Mark
smunagap
Yes,this is supported config.
Can you please collect
show controller tengig <> internal
show controller tengig<> phy in problem state.
