ASR9k IPoE static IP binding with dot1q interface per vlan
NayatelPakistan
I connected  IPOE subscriber through separate sub-interface on ASR9001 OS V 6.4.2 using DHCP initiate . Now subscribers are being assigned IPs through DHCP but what i want is to assign IP to the customer on the bases their NAS port id which i have customized as pasted below.
Nov 26 11:49:22.373 GMT: radiusd[1153]: RADIUS: NAS-Port-Id [87] 22 Bundle-Ether142.4000
Radius will forward this attribute to data base where IPs wil be binded against "Bundle-Ether142.4000" value. Actually i want to how i could achieve this using COA or other AAA options running is pasted below. Please guide.
@xthuijs you are specially requested to assist.
aaa group server radius BNG
server 172.16.149.102 auth-port 1812 acct-port 1813
source-interface Loopback70
aaa authentication ppp default group BNG
address-family ipv4 unicast
pool vrf default ipv4 IPSUB
network 172.16.21.104/29
dhcp ipv4
profile IPSUB server
pool IPSUB
dns-server 101.50.101.50
default-router 172.16.21.110
interface Bundle-Ether142.4000 server profile IPSUB
interface Bundle-Ether142.4020 server profile IPSUB
ipv4 point-to-point
ipv4 unnumbered Loopback70
ipv4 verify unicast source reachable-via rx
service-policy type control subscriber POL_IPSUB
encapsulation dot1q 4000
ipsubscriber ipv4 l2-connected
initiator dhcp
ipsubscriber ipv6 l2-connected
initiator dhcp
ipv4 point-to-point
encapsulation dot1q 4020
initiator dhcp
initiator dhcp
ipv4 address 172.16.21.110 255.255.255.255
aaa attribute format MY_AUTH
mac-address plus circuit-id plus remote-id separator #
aaa attribute format NAS-PORT-ID-FORMAT2
format-string length 253 "Bundle-Ether%s.%s" physical-port outer-vlan-id
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU type 40
aaa radius attribute nas-port-id format NAS-PORT-ID-FORMAT2
aaa accounting subscriber default group radius
aaa authorization subscriber default group radius
aaa authentication subscriber default group radius
class-map type control subscriber match-any CLASS_IPSUB
match protocol dhcpv4
end-class-map
policy-map type control subscriber POL_IPSUB
event session-start match-first
class type control subscriber CLASS_IPSUB do-until-failure
1 activate dynamic-template IPSUB
10 authorize aaa list default format MY_AUTH password test
end-policy-map
xthuijs
the local dhcp server in xR can only pick adds based on giaddr or that is the ip addr of the interface/unnumbered associated with the subscriber.
what you can do is to create a username for the subscriber composed of the nas-port id.
than send it off to radius for authentication
use username and or nas-port-id as part of the check items
and send back framed-ip address netmask dns and default gateway to fill the offer for dhcp to send back.
this requires profile bASE however.
cheers!
xander
Thanks xander for your prompt response!
I am glad that you explained the logic for achieving this. Would you please share how i can configure a profile base. Any informational link or sample will be helpful
