ASR9K mrib[1145]: %ROUTING-MRIB-3-TLC_ERR : No TLC entry (lcl/add) while processing fwd upd, lcl_tid 0xe0000000
We ran into this tonight turning up some ASR9001 boxes.  Looking for more information.
Log message:
RP/0/RSP0/CPU0:2016 Jun 13 23:26:16.860 UTC: mrib[1145]: %ROUTING-MRIB-3-TLC_ERR : No TLC entry (lcl/add) while processing fwd upd, lcl_tid 0xe0000000, rem_tid 0x0, nodeid 0x821, cons_pid 0, self_pid 717117
Bug info:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq78451/?referring_site=bugquickviewclick
ASR9001 patched current as of 06/09/2016:
RP/0/RSP0/CPU0:FLVL-9001-1#admin sh install summ
Tue Jun 14 01:04:00.362 UTC
Default Profile:
  SDRs:
    Owner
  Active Packages:
    disk0:asr9k-fpd-px-5.1.3
    disk0:asr9k-k9sec-px-5.1.3
    disk0:asr9k-mcast-px-5.1.3
    disk0:asr9k-mgbl-px-5.1.3
    disk0:asr9k-mini-px-5.1.3
    disk0:asr9k-mpls-px-5.1.3
    disk0:asr9k-px-5.1.3.CSCut52232-1.0.0
    disk0:asr9k-px-5.1.3.CSCud65530-1.0.0
    disk0:asr9k-px-5.1.3.CSCum93144-1.0.0
    disk0:asr9k-px-5.1.3.CSCup67076-1.0.0
    disk0:asr9k-px-5.1.3.CSCup67367-1.0.0
    disk0:asr9k-px-5.1.3.CSCuq02868-1.0.0
    disk0:asr9k-px-5.1.3.CSCuq15193-1.0.0
    disk0:asr9k-px-5.1.3.CSCuq41132-1.0.0
    disk0:asr9k-px-5.1.3.CSCuq95565-1.0.0
    disk0:asr9k-px-5.1.3.CSCur14841-1.0.0
    disk0:asr9k-px-5.1.3.CSCur25073-1.0.0
    disk0:asr9k-px-5.1.3.CSCur31362-1.0.0
    disk0:asr9k-px-5.1.3.CSCur39933-1.0.0
    disk0:asr9k-px-5.1.3.CSCur42755-1.0.0
    disk0:asr9k-px-5.1.3.CSCur50363-1.0.0
    disk0:asr9k-px-5.1.3.CSCur83427-1.0.0
    disk0:asr9k-px-5.1.3.CSCus22621-1.0.0
    disk0:asr9k-px-5.1.3.CSCus22641-1.0.0
    disk0:asr9k-px-5.1.3.CSCus26923-1.0.0
    disk0:asr9k-px-5.1.3.CSCus50857-1.0.0
    disk0:asr9k-px-5.1.3.CSCus79201-1.0.0
    disk0:asr9k-px-5.1.3.CSCut07590-1.0.0
    disk0:asr9k-px-5.1.3.CSCut11994-1.0.0
    disk0:asr9k-px-5.1.3.CSCut19656-1.0.0
    disk0:asr9k-px-5.1.3.CSCut47229-1.0.0
    disk0:asr9k-px-5.1.3.CSCut49958-1.0.0
    disk0:asr9k-px-5.1.3.CSCut57146-1.0.0
    disk0:asr9k-px-5.1.3.CSCut62521-1.0.0
    disk0:asr9k-px-5.1.3.CSCut69575-1.0.0
    disk0:asr9k-px-5.1.3.CSCut87466-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu02307-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu20681-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu49257-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu50793-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu69916-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv06002-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv27439-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv27556-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv38338-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv68172-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv94061-1.0.0
    disk0:asr9k-px-5.1.3.CSCuw35268-1.0.0
    disk0:asr9k-px-5.1.3.CSCuw36137-1.0.0
    disk0:asr9k-px-5.1.3.CSCuw57096-1.0.0
    disk0:asr9k-px-5.1.3.CSCuw70800-1.0.0
    disk0:asr9k-px-5.1.3.CSCux07545-1.0.0
    disk0:asr9k-px-5.1.3.CSCux12491-1.0.0
    disk0:asr9k-px-5.1.3.CSCux57093-1.0.0
    disk0:asr9k-px-5.1.3.CSCup96426-1.0.0
    disk0:asr9k-px-5.1.3.CSCur48291-1.0.0
    disk0:asr9k-px-5.1.3.CSCuw26572-1.0.0
    disk0:asr9k-px-5.1.3.CSCux24553-1.0.0
    disk0:asr9k-px-5.1.3.CSCux27300-1.0.0
    disk0:asr9k-px-5.1.3.CSCux86021-1.0.0
    disk0:asr9k-px-5.1.3.CSCuy27610-1.0.0
    disk0:asr9k-px-5.1.3.CSCuy33320-1.0.0
    disk0:asr9k-px-5.1.3.CSCuy70644-1.0.0
    disk0:asr9k-px-5.1.3.CSCuy76948-1.0.0
    disk0:asr9k-px-5.1.3.CSCuz05193-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu37646-1.0.0
  Inactive Packages:
    No packages.
  Committed Packages:
    disk0:asr9k-px-5.1.3.CSCuj32250-1.0.0
    disk0:asr9k-px-5.1.3.CSCuj73764-1.0.0
    disk0:asr9k-px-5.1.3.CSCuo30675-1.0.0
    disk0:asr9k-px-5.1.3.CSCur69331-1.0.0
    disk0:asr9k-px-5.1.3.CSCus71103-1.0.0
    disk0:asr9k-px-5.1.3.CSCut04689-1.0.0
    disk0:asr9k-px-5.1.3.CSCuu77478-1.0.0
    disk0:asr9k-px-5.1.3.CSCuv71271-1.0.0
    disk0:asr9k-px-5.1.3.CSCuw01943-1.0.0
    disk0:asr9k-px-5.1.3.CSCux15936-1.0.0
    disk0:asr9k-px-5.1.3.CSCux16975-1.0.0
    disk0:asr9k-px-5.1.3.CSCux19443-1.0.0
  Superceded Packages:
Sunil Bhadauria
Hello Benjamin ,
seems like you may be pointing to right ddts here. You could follow conditions mentioned in this ddts further to verify if you are hitting this ddts in this case .
conditions mentioned in this ddts says that :
<snip>
multicast is enabled on BVI and IGMP snooping is configured in a bridge domain.
The message is generated on an mrouter add/remove event in an igmp group
<snip>
- you may want to verify you l2vpn configuration to see any such configuration under any bridge-domain. If there is any such configuration then we are hitting this ddts.
further information on this ddts :
- These logs are cosmetic in nature and so no service impact because of them.
- there is no workaround for this in current code and 5.3.3 will be having the fix for it.
Sunil
To acknowledge, kindly rate all valuable responses
Thank you for the quick response.  Yes, we do have a BD with BVI with IGMP snooping.
Is suppression logging recommended in this case?  I have run into a similar cosmetic bug where they recommended supression logging, although customers typically don't like that approach because they feel it can hide actual issues.
Another cosmetic bug I reported here:
https://supportforums.cisco.com/discussion/13012706/cscus08820-platform-canbserver-3-messagefailed-asr-9001-fan-v2-1
Hello Benjamin ,
So condition matches as well . To me looks like the same ddts (CSCuq78451).
For you next query , considering this is cosmetic issue as interim workaround you could use log suppression to  stop these messages in logs.
Sunil
