ASR9K POwer Modules V2
dlarade
Would anyone know where to find the Wiring Schematic on how these PEM Power Modules are internally wired? Want to know if PS0 M0 A side
is a common point as PS0 M0 B Side.
Dave
Aleksandar Vidakovic
hi Dave,
I suppose this is the information that you are ultimately looking for:
DC Power Version 2
  • DC V2 PS delivers up to 2.1 kW to the system
  • Power tray holds up to 4 DC V2 power supplies
  • Dual input feed
  • Feed redundancy is built into the PEM – logical “OR” between feeds. If one feed fails, PEM still delivers 2.1 kW
AC Power Version 2
  • AC V2 PS delivers up to 3 kW to the system
  • Power tray holds up to 4 AC V2 power supplies
  • Single input feed
  • Feed redundancy achieved by using multiple power supplies
hi Dave,
DC Power Version 2
  • Dual input feed
AC Power Version 2
  • Single input feed
So in the DC Power version 2.
If the Power module say in PS0 "M0" is fed an A feed from a DC source and also fed a B feed, Are they independent of each other until one feed fails?
so in essences you have only the A feed "Active" until it fails then B Feed kicks in?
Dave
