ASR9k USB boot
seek_1992
Hi all
I was trying to password recovery my ASR 9006. in process of struggling to get into ROMMON which I wasn't able, the IOS XR crashed. When I trying to boot from USB (FAT32 filesystem) following message is shown. It worth mentioning that I had tried various methods of making the USB bootable by third-party software and then copying the content of the file "asr9k-mini-x64-6.6.3.iso" into the USB (In another case I just copy the ISO file into the USB). However, I face the following error when trying to boot from external USB (option 7):
Press Esc for boot optionsMAC is for internal NIC interface:
MAC is not same:
MAC is for external niantic interface:
MAC is not same:
TriggerCpFpd
ASR9K FPD Starting ASR9k fpd check ...
No BIOS file found(2)
No BIOS file found(14)
K▒▒▒ Network 1 for IPv4 (4C-71-0D-C4-67-E0) not matching with EMT:4
Boot Option:Internal Network 0 for IPv4 (90-E2-BA-48-39-70) VLAN(3073) not matching with EMT:4
Boot Option:External Network 1 for IPv4 (FF-FF-FF-FF-FF-FF) not matching with EMT:4
Boot Option:ADATA USB Flash Drive not matching with EMT:4
Boot Option:SMART eUSB HS-SD/MMC not matching with EMT:4
Boot Option:Micron_5100_MTFDDAV240TCB not matching with EMT:4
Boot Option:Internal EFI Shell not matching with EMT:4
Boot Option:CISCO iPXE not matching with EMT:4
MAC is not same:
MAC is not same:
any help is much appreciated.
 Seek
smilstea
So for cXR we need the mini.vm to turboboot the router, not related to password recovery.
eXR which you have has no method of password recovery so you have to PXE boot the box / USB boot.
You can follow the below guide for USB boot:
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-5/system-setup/configuration/guide/b-system-setup-cg-asr9000-65x/b-system-setup-cg-asr9000_chapter_010.html#task_bcp_m32_cdb
Sam
smilstea
Sam
ehab.saber
Where can I get the "usb-install.sh" script?
