BGP on A9K: Filtering prefixes using Communities on iBGP
dfranjoso
We are trying to filter some prefixes to a iBGP connection but it doesn't work properly:
The rpl is like this:
community-set MID
  15525:8657
end-set
route-policy Deny_Community_MID
  if community matches-any MID then
    drop
  else
    pass
  endif
end-policy
This rpl only removes the community from the prefix, and the prefix always arrive on the iBGP neighbor, which it not what we intend to do ! What we intend to do is to filter out the prefix ...
On our research we find this which is absolutely different from the IOS behaviour ...
BGP community and extended-community filtering cannot be  configured for iBGP neighbors. Communities and extended-communities are  always sent to iBGP neighbors
on
http://www.cisco.com/en/US/partner/docs/routers/asr9000/software/asr9k_r4.0/routing/configuration/guide/rc40asr9k_chapter1.html#task_1211424
Is this true or are we seeing this the wrong way?
Thank you!
Works for me too.
Seems to be a documentation issue coming back from 3.4 release.
/A
8 Replies 8
dfranjoso
My mistake. The prefixes are actually being filter! Still i don´t understand what is meant on this sentence from the IOSXR configuration guide.
Anyone understands this ?
Thanks!
Works for me too.
/A
dfranjoso
Thanks Akiritch. Is it possible to open a documentation bug to correct it ?
there is a feedback form at the bottom of the document. let's see if that works  (I am interested myself)
may you try?
/A
Done! But i have several more examples on the poor and buggy IOSXR documentation .. :
Command Reference A9K 4.0, BGP Chapter:
                The commands “additional-paths” should have a brief explanation stating that they belong the PIC Edge Framework .. but nothing .. No usage guidelines
Command Reference A9K 4.0, IS-IS Chapter:
The command “ipfrr” is deprecated and replaced by “fast-reroute” but still appears on documentation ..
Configuration Guide A9K 4.0, Routing Chapter:
                There is no reference to PIC anywhere .. only a couple of meaningless words
i'll check it.
/A
we've opened following request to correct the documentation
CSCtx13654    Correct Routing CG and CR documentation based on feedback from XR Forum
regards,
/A
Hi Alexi,
                                May I know how to configure "IP address-specific extended community" (
BGP Extended Communities Attribute) in IOS XR ??
